Old 03-24-2022, 07:00 PM
GTOKIDRH's Avatar
GTOKIDRH GTOKIDRH is offline
Default ,'67 Executive Safari rear differential?
What rear end was used in '67 B body wagons? Mine has a 2.41 Saf T Track. Was it the 8.2" BOP 10 bolt? Looking to change to a 3.23 or 3.42.
Old 03-24-2022, 08:50 PM
694.1 694.1 is offline
Not the 8.2, it was the '65-'70 Pontiac full size rear. Kinda scarce.
Still have my 1st Firebird
7th Firebird
57 Starchief
The Following User Says Thank You to 694.1 For This Useful Post:
Old 03-24-2022, 09:12 PM
GTOKIDRH's Avatar
Are there aftermarket carriers and gear sets available for them?
Old 03-24-2022, 09:23 PM
Stuart's Avatar
Stuart Stuart is offline
There's a 3.42 posi for sale in the want ad section: https://forums.maxperformanceinc.com...d.php?t=857537
The Following User Says Thank You to Stuart For This Useful Post:
Old 03-25-2022, 08:58 AM
rustyrelic rustyrelic is offline
See the thread below on big car posi. Appreciation for the fullsize is called the darkside for a reason.
The Following User Says Thank You to rustyrelic For This Useful Post:
Old 03-26-2022, 11:48 AM
GTOKIDRH's Avatar
I bought a '71-'76 posi 3:23 rear end for $1000. It has the 10 bolt cover and 12 bolt ring gear. It's a leaf spring setup but I'm hopeful that what I've read is true and I can swap the carrier and gears into my '67 housing.
Old 03-26-2022, 05:31 PM
GTOKIDRH's Avatar
Fabcraft's install kit says '65-'76 so all should be fine.
