Old 04-02-2022, 07:46 PM
455 pontiac's Avatar
455 pontiac 455 pontiac is offline
Default New Best
Went a new best today
535 pump gas with some 112 for a safer tune. 3710# with driver
1969 LeMans..Liberty Blue
2001 WS6..Sunset Orange
1973 Pro Street Firebird..Lucerne Blue
Old 04-02-2022, 07:55 PM
grandam1979 grandam1979 is online now
Very nice congratulations
Old 04-02-2022, 08:54 PM
Gary H's Avatar
Gary H Gary H is offline
Very nice! Great 60" time for the ET too.
Old 04-02-2022, 09:29 PM
PAUL K's Avatar
PAUL K PAUL K is offline
That's getting it done! Good job!
Go fast, see Elvis!
Old 04-02-2022, 10:01 PM
aaronman aaronman is offline
Nice MPH as well! Congratulations!
Old 04-03-2022, 05:15 AM
chuckies76ta's Avatar
Nice times. Congrads
Old 04-03-2022, 06:52 AM
25stevem's Avatar
25stevem 25stevem is offline
Very nice for that weight!
Keep in mind though that running any octane level above what you need to keep detonation at bay will cut into the HP numbers.
I do stuff for reasons.
Old 04-03-2022, 07:46 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Congrats Jeff!!!!! Always a great day at the track when you get a new best
Chris D
69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60'
Old 04-03-2022, 09:38 AM
ponjohn's Avatar
ponjohn ponjohn is offline
That's awesome.
Is the car caged?
Old 04-03-2022, 09:43 AM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
Very nice!! Glad to hear of the new best. Care to share the specs of the combo?
Old 04-03-2022, 11:10 AM
Originally Posted by ponjohn View Post
That's awesome.
Is the car caged?
Yes 8.50 cert
Old 04-03-2022, 01:12 PM
grandville455's Avatar
grandville455 grandville455 is offline
Congrats! How come 112 is pump gas?? I ran straight 91 on my 11.1 pump gas 505
Darby
74 Grandville 2Dr 455 c.i 4550#
2011 1.60 60 ft,7.33@94.55-11.502@117.74
2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32
M/T 275/60 ET SS Drag Radial
2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's
Old 04-03-2022, 01:28 PM
I never said 112 was pump gas. Motor is 11.1. and will run on pump gas which I run on the street. I choose to run some 112 at the track for a safer tune considering the junk gas at the pump.
Old 04-03-2022, 01:42 PM
I have done the same so far. Mine is just over 11 to 1 . I think it's safe on pump gas but mix a gallon or so of 110 in to be sure. At least until I am sure of the tune.
Old 04-03-2022, 03:19 PM
That was a misprint on my phone sorry, supposed to be if not is! I get being safe but if the tune is on at that comp u wouldn’t have to worry,
Darby
Old 04-03-2022, 04:56 PM
No problem... thanks
Old 04-03-2022, 05:32 PM
Dragncar Dragncar is online now
That is a nice time slip. 60 foot, mph for the weight. Can we get more info on the top end, cam ?
Old 04-03-2022, 06:20 PM
High ports cnc by SD, northwind intake, 1100 pro systems carb. Custom comp cams solid roller. Turbo 400 with TB 9" ati converter. 31x14 tire with 456 gear
The Following User Says Thank You to 455 pontiac For This Useful Post:
Old 04-03-2022, 06:39 PM
77 TRASHCAN's Avatar
77 TRASHCAN 77 TRASHCAN is online now
To Quote Jerry Reed form Smokey and the Bandit!!!
Boogity, Boogity, Boogity!!!
Shut it off
Shut it off
Old 04-03-2022, 07:35 PM
AG's Avatar
AG AG is offline
Great 60' time. My car is 11.2 CR and I run 93 pump without issues. I've had the motor apart and no signs of detonation.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
