Old 04-07-2022, 07:24 AM
Adecco Adecco is offline
Default 1971 GTO Crager rear wheel 15x8 or 15x10
Ok this is old school and since Cooker Tires is coming back with the Crager SS wheel in particular 15 x 4.5 for the front I am going to go back to the Old School look so here is my question?
15 x 8 with a 4.5" backspace
or
15 x 10 with a 4.5" backspace
Maybe an N50 or 60 series tire and a skinnies on the front.
Thanks Tom
Old 04-07-2022, 07:56 AM
scott70's Avatar
scott70 scott70 is offline
If I were running a 8" wide rear tire Id go with 15x8 rim....the 15x10 would be too much tire roll for me. Also I used to have 15x10 rear rims with 4.5BS and a 10.5" tire. I had to trim the fender lip to get it to clear on a 72 lemans. I think I had the clearance for a 5" BS but never tried it. Or you could jack the back way up for a old school look and not have any rear tire rub. Right now I have a rear 15x8 rally 2 with 4.5BS and a 8.25" wide tire and fits good without rubbing.
1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86'
Old 04-07-2022, 08:28 AM
Thanks .. as the saying goes "old things come back in style" seeing a lot of this in the midwest...
Old 04-07-2022, 11:28 AM
DavesGTO's Avatar
DavesGTO DavesGTO is offline
Bought some centerline champ 500 rims when I was 19 which I still have and the rear ones were 10 in 4.5 backspace. Car was hit on the front so frame was bent somewhat , they only rubbed on the passenger side? Always wondered if the body was centered on the frame if they wouldn’t rub? I think if you don’t get 5” backspace they will rub, might rub on inside maybe with the 50’s ? I do like the look, might put mine back on one day.
Old 04-07-2022, 02:21 PM
skipp65 skipp65 is offline
Following this thread, I've been thinking the same thing with my 72, wondering how 10x15 5bs with 275-60 would look? I won't trim fender lip or roll it so I wonder how close tires will be. I haven't pulled the trigger on the rims yet, don't want to regret a purchase.
Old 04-07-2022, 02:32 PM
Something about this look from the back ...and side just is MEAN ...
