Old 05-11-2022, 04:34 AM
dataway's Avatar
dataway dataway is offline
Default AC O-ring kits
Can someone recommend a good o-ring kit for the AC system on a 68 GTO with A6 compressor.
I need one that has the o-rings for the drier, the drier extension tube etc.
Needs to be R12/134 compatible. I see a lot out there but no idea if they include things like the Pontiac specific extension tube orings, or which brands are any good.
Also ... does anyone sell just the hose? I see all the hoses with fittings, but how about just plain hose for the sections with no fittings?
Old 05-14-2022, 03:28 AM
dataway's Avatar
Anyone?
Old 05-14-2022, 09:56 AM
mzbk2l's Avatar
mzbk2l mzbk2l is offline
Sorry I can't answer your question, but I can tell you I buy the $15 "R-134a o-ring assortment" kits from Amazon and they mostly never have what I need. I did my neighbor's Super Duty (ford, not Pontiac) the other day and my kit didn't have the condenser o-rings. You might get lucky and find all the correct sizes in a kit like that, or you might be better off removing each of your o-rings and going in to a NAPA or somewhere to pick through their assortment (which is hopefully larger than what you'd get in a generic kit you'll end up throwing away mostly unused in 15 years).
Mike
The Following User Says Thank You to mzbk2l For This Useful Post:
Old 05-14-2022, 12:42 PM
RFCOLEMAN RFCOLEMAN is offline
You could try The Original Air Group.
https://www.originalair.com/replacement-parts
The Following User Says Thank You to RFCOLEMAN For This Useful Post:
Old 05-15-2022, 02:09 AM
dataway's Avatar
Old Air says they have a kit, doesn't specify whether it has the condenser drier orings. I've got plenty of o-rings here ... but they are generic, not sure if they are suitable for AC systems.
Old 05-15-2022, 12:31 PM
FrankieT/A's Avatar
I only use the green ones originally designed for Fords.
The Following User Says Thank You to FrankieT/A For This Useful Post:
Old 05-15-2022, 03:25 PM
A call to Old Air should clarify what they would be sending you.
The Following User Says Thank You to tjs72lemans For This Useful Post:
Old 05-16-2022, 05:35 AM
dataway's Avatar
Shot them an email, should hear back today.
Old 05-23-2022, 07:56 AM
dataway's Avatar
I've got the typical box set of o-rings, kind of a standard item for a well equipped shop .. but I have doubts about using them in an AC system.
Old 05-23-2022, 09:02 AM
FrankieT/A's Avatar
I only use the green "O" rings originally designed by Motorcraft regardless of what brand vehicle I'm working on and never have a problem.
Old 05-23-2022, 09:49 AM
mzbk2l's Avatar
The $15 "R-134a o-ring assortment kits" I mentioned in post 3 are the green O-rings for R-134a and PAG oil. I still haven't had great luck with them fitting what I need... if the ID is right, it's not thick enough. If it's thick enough, I have to stretch it. They work for about 75% of the average job, but if I have to go to the store to match up the one o-ring the kit didn't have, I might as well go buy all new ones.
Mike
