OHC-6 TECH Over Head Cam projects, questions and advice.
Old 05-11-2022, 09:37 PM
Hokie1984 Hokie1984 is offline
Default Harmonic balancer marks
67 Sprint for reference. Are there marks on the harmonic balancer to check if the outer ring is lined up correctly. I am needing to advance the timing pretty far to get it to be responsive to throttle bumps. Also the vacuum gauge indicates late timing when at 5 degrees. Thank you in advance.
Old 05-12-2022, 06:00 AM
Jeff Hamlin's Avatar
Yes both for timing reference as well as for slippage indication.
Old 05-12-2022, 06:02 AM
Thanks again Jeff.
Old 05-12-2022, 06:12 AM
Thanks again Jeff.
