Old 05-14-2022, 05:41 PM
grandam1979 grandam1979 is offline
Default 65 tach in a 64??
Has anyone put a 65 tach in a 64? I see the clock is interchangeable.
Old 05-14-2022, 06:42 PM
Tom Vaught's Avatar
Boost Engineer
I put a complete 1965 Gage assy in my 64 GTO.
When I got the Car from Pontiac the Brass Hat (or one of his people) had installed a 1965 Wood Dash insert.
I later found out from John V that it was another "Mod" the Executive had someone in Pontiac install in his car.
Maybe the wife did not like the Swirl Aluminum dash insert.
But now, I know based on John V's input.
Jack Watson told me he did the same to his Blue Car, during a conversation at his shop in Mt Clemens, Mi.
I firmly believe that Blue car was not crushed.
So enough history, Put the 65 Cluster or Just the Tach in your car if YOU WANT. It is your car.
Tom V.
Old 05-15-2022, 10:22 PM
ron cozzo's Avatar
ron cozzo ron cozzo is offline
65 gauges looks great with the 64 engine turned aluminum dash.
Name:	2013-08-03 1964-pontiac-gto-dash-view.jpg
'04 GTO Yellow Jacket, A4, Kooks, CAI, etc.
'02 Firebird, V6, auto
'68 GTO Convertible, HO, 4spd, driver
'66 LeMans Hardtop, 400, FI, A/C, 4L80E.
'64 GTO Hardtop, "389", Tri-power, 5 speed, A/C, Yorktown Blue.
http://www.gtoaco.com
Old 05-16-2022, 03:29 PM
Tom Vaught's Avatar
Boost Engineer
HAVE TO AGREE WITH THAT STATEMENT. TOM V
Old 05-16-2022, 05:31 PM
Old Goat 67's Avatar
Charles B
Old 05-17-2022, 09:29 PM
John V. John V. is offline
I have considered the lack of Rally Gauges being offered for the '64 a big bummer and the Rally Gauge option for '65 rectified that. Many have swapped the complete '65 Rally cluster into the '64. I'm a '64 guy but the Rally Gauges are one of a few things that I envy about the '65.
However, it would be tricky to swap a '65 Tach by itself into a '64 which, if I read your question correctly, is what you are asking.
In '64, the RH pod location was independent of the rest of the cluster. Standard car simply got a "dummy" blank-off plate in that pod, '64 and '65.
The other 3 pod locations used a common cluster housing.
As optional equipment in '64, you could choose the Rally Clock (which I always thought was awesome looking) or a Tach. Since the Tach and Clock were designed to occupy the same RH pod location, you could NOT order both.
In '65, that changed. The Rally Clock could be had with the standard idiot light instrumentation, same as in '64.
Same as in '64, you could not get both the Clock and Tach.
But the '65 Tach was made part of the Rally Gauge option and was placed in the right center middle pod location which was in the common 3 pod housing. The independent RH pod location was used for the Temp and Oil Pressure gauges within the single pod housing (see the pic Ron posted for the layout as seen from the front side).
Aside from the '65 Tach having a Black face while the standard instrument faces are Blue, I'm not sure how you could install a '65 Tach in combination with the '64 cluster. Perhaps the '65 Tach can be fit into a '64 Tach housing? If that worked, I would try to have the dial face changed to a Blue background to match the other gauge faces, maybe Peter Serio could make that happen.
Point is, unlike '64, the '65 Tach is not directly interchangeable with the Rally Clock since it does not install in the same pod location and did not use an independent housing.
Personally, I think the '64 Tach gets a bad rap. I'm not a racer but I don't have trouble checking revs on my '64 Tach, I think it looks cool too. The smaller sweep I suppose makes it relatively less accurate. But if I needed precise accuracy, I probably wouldn't trust a factory Tach.
The lack of gauges in '64 is the bigger issue so I have added a set of Autometer gauges which for someone like me who prefers factory original is a bit of a disappointment.
In later years, PMD figured out a way to have gauges, Tach, and a Clock. In the early '70s I would drag home Rally Clocks from salvage yard early GTOs and other A bodies whenever I was there to find a needed part just because I thought the Clocks looked so cool. In the end, I installed a Tach that I had scored but I've always been torn in choosing one over the other.
If you are looking to put a complete '65 Rally Gauge cluster in a '64, I'd say go for it. I agree they look great.
One caveat, the '65 fuel gauge sender is different from the '64 so I believe you will need to use a '65 sender. You would also need the appropriate Temp and Oil Pressure senders to make those gauges work in place of the idiot lights.
One thing I like about having the underdash Autometer gauges, I get to retain the original Oil Pressure sender for the idiot light and I also have a Voltmeter in addition to the Battery idiot light. The analog gauges are good but the idiot light, especially for Oil Pressure, might draw more immediate attention in the event of a serious issue. I don't have a working Temp light although even that could be done.
The Following 2 Users Say Thank You to John V. For This Useful Post:
Old 05-23-2022, 03:41 PM
So after a little research has anyone used the tach offered that looks stock but actually goes into the right hand pod that the clock usually goes in?
Old 05-23-2022, 09:00 PM
Rich-Tripower's Avatar
We used one of the reproduction tachs in our 64. Seems to work fine and looks pretty nice. Been in the car a couple of years now, never a problem.
ID:	591406   Click image for larger version
The Following User Says Thank You to Rich-Tripower For This Useful Post:
