So I got my dash pad removed so that way I could put a new speaker underneath but whenever I got the passenger side out the clip that goes in the dashboard area came out and I've looked for three weeks and cannot find it anywhere in the car does anybody know where I can locate these?
Looks similar to what is used on other full wrap around dash pad & metal dashes, look up ones used for a 68 gto to compare.
-Jeremy 1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio. 1962 Catalina convertible, Starlight black w maroon interior & white top. |
Restoration Specialties?
The Following User Says Thank You to pfilean For This Useful Post: | ||
Look the same as 68 AC dash pad clips ... I've never seen them reproduced, all I could find were the square dash pad clips which I think were used in the non-AC 68 dash pads.
I'm World's Best Hyperbolist !! |
Is that a cage nut? if so they are readily available from places like fastenall.
It's a clip that holds a push-in pin with a knob on the end.
They are a strange spring steel clip. As far as I know, they are 66 full size car only. They are definitely different than a 65, which are plastic. I have 2 NOS clips here I will send you. PM me your address. You can have them.
The Following User Says Thank You to mgarblik For This Useful Post: | ||
Oh my gosh that would be amazing thank you very much I'm fairly new to the site so it might take me a little while to figure out how to send you a PM
Click on the members name. A drop down menu will enable you to send a private message.
When a message is received from someone, it will show under your name at the upper right hand corner the top of the page. Click on Private message.
Ed 1968 GTO (Thanks Mom) 2006 Silverado 2007 Cadillac SRX 2015 Chevy Express ![]() 2024 Cadillac LYRIQ |
The Following User Says Thank You to OG68 For This Useful Post: | ||
In a pinch I bet a fender washer and a wing nut would work in absence of the clips.
