1967 326 overheating
Hello,
I have a 1967 firebird convertible with a 326 engine. It is punched out 1 over with an edelbrock high rise and a small cam. Problem is its over heating to around the 210 degree mark. Does anyone have an idea on what water pump would be the best on it? I really do not want to change out the whole front of the engine. Help is appreciated Thanks |
210 degrees is not really overheating. Antifreeze/water mix under pressure doesn't boil to over 260 degrees. If you have the original radiator it is probably time for a new aluminum one. Any of the major brands are good.
The Following User Says Thank You to Goatracer1 For This Useful Post: | ||
Please give more details!
We need to know when Temps are raising . At road speed above 30 mph ? At a light ? Does the temp creep up at a light and then not really go back down? One simple , cheap and fast thing to give a shot is use DuPont’s two part flush. You will be shocked at how much crap and rust scale this will remove from both the block and the Rad!
I do stuff for reasons. |
That DuPont stuff is called Cooling System Cleanser. It's a caustic cleaner and really does an excellent job. It's a little hard to find. Follow the directions exactly as if not neutralized it will continue to eat away at the metal in the system.
The Following User Says Thank You to mgarblik For This Useful Post: | ||
If it turns out that you still need a new rad after the HD flush, then pull the pump out too just to look at it.
If it was replaced at some point in time with a pump that uses steel fins like a Alternator fan, then get that pump the hell into a scrap heap and be sure to buy one with a cast iron ( factory type ) vane type impeller .
check the 2 water pump plates in the timing cover to see if they have any holes from corrosion.
I had a 68 that running hot and couldn't figure out until i found a hole in the plates. Changed them and no more problem. What thermostat are you running?
You never know what I might have that you are looking for. EMAIL me. Also check out my other ads here on PY. Just click on user name to view other ads. USPS Money Orders or Wal-Mart to Wal-Mart money gram wire transfer -preferred payments. If Payment doesn't show up in 3-4 days, I move on to the next person that wants it. Serious Inquiries Only - Shipping Isn't Free. |
