Old 07-11-2022, 09:49 PM
4dblnkldude's Avatar
Default Newbies racing at Norwalk
So my buddy and are bringing his 70 lemans. We will probably pull into linders lot early evening on Thursday. I think they let you in the pits in the morning? Do they allow antifreeze in the cars? Were teetering around the roll bar rule, if he runs an 11.49 will they kick us off? Any tips for some Norwalk racing rookies?
Old 07-12-2022, 07:46 AM
RA462's Avatar
RA462 RA462 is offline
I believe on Thursday they start letting people into the track around 3 to get setup. If you show up late enough on Thursday they may have you wait in Linder's lot overnight. I'm not sure what time that is as I'm always there Thursday morning. They may tell you to slow it down if you go faster then the roll bar rule but I don't think you will be kicked out. I have raced my street car with antifreeze in the past with no problem. As far as a tip I would say make sure you have a way to get around other then just walking. Hope this helps.
Todd Sedlmeier
Who ever thought pinewood derby cars would lead to this!
October 2004 HPP Shootout participate
http://www.highperformancepontiac.co...out/index.html
86 Grand Prix
535 High Port 8.93 @ 153
65 GTO
433 High Port 12.04 @ 113
Old 07-12-2022, 07:59 AM
Cliff R's Avatar
Cliff R Cliff R is offline
Anti freeze is fine provided you're not "puking" it out in staging or on the track.
Make a flat out pass to see where the car is at. IF you are quicker than 11.49 you can make changes to slow it down to be legal. Every 100 pounds kills apprx a tenth. Retarding the timing will take some out of it as well. So will short-shifting.
I did all three depending on the weather and where the car was at. It's hot/humid here in Ohio in August so the car will be at it's slowest or close to it anyhow. The best option is adding weight. Weight in the trunk slows the car and makes it hook better so more consistent. I used to add 200 pounds to the trunk, retard the timing to 26 degrees total and short shift at 5000rpm's vs 5800. Typically that would take the car from low 11's to 11.50-11.70. The car hooked solid and it kept the track officials from visiting the pit sight and giving me a warning.
Below is a run at Norwalk doing with weight added, timing retarded and shifting at 5000rpm's......
https://www.youtube.com/watch?v=6zVdoLR-VzM
The Following User Says Thank You to Cliff R For This Useful Post:
Old 07-12-2022, 11:32 AM
sdbob sdbob is offline
There is a lot ,to see,experience take in. As Todd said you should have wheels,golf cart,etc to get around. Hone your reaction times, later rounds are tuff. Lots of nice people,most of all have fun,oh get your ice cream before its gone!
Old 07-12-2022, 09:38 PM
Thanks fellas! Cliff, it looked like you let odd a tad before the traps... or did you?
Old 07-12-2022, 09:58 PM
Bills Auto Works's Avatar
Bills Auto Works Bills Auto Works is offline
You will have a BLAST!
I have been racing there on & off since 1978, lots has changed from back then when it was grass, gravel & mud! LOL
In the old days a "catch can" was required but that may have changed. I have not paid much attention to rules changes in the last decade as the only thing I run is just a one pass blast to see how it runs.
I should be there all weekend (as I only live 13 miles from the track) with my 64 GP if I get it done in time...Hopefully!
God bless
Bill
https://www.jalopyjournal.com/forum/...closed.614419/
Name:	20220208_144239 (800x600).jpg
ID:	594219   Click image for larger version
Name:	20220620_163949 (800x600).jpg
Your QUALITY Pontiac Transporter Since 1983
Bills' Auto Works Est 1983 & still going strong!
1955 Chevy Altered W.B. Gasser
1955 Nash Ambassador Custom Lemans
1964 Grand Prix
1966 Catalina Conv. 421+
1966 Ambassador DPL 2dr HT
1966 Ambassador Cust. 2 DR HT
1967 Marlin
1967 Toronado
1973 Nova Full Chassis Car
1992 Jag XJS Conv
1992 Jag XJS Coupe
2007 Cad XLR-V Supercharged Roadster
The Following User Says Thank You to Bills Auto Works For This Useful Post:
Old 07-13-2022, 03:17 PM
Old Goat Racer's Avatar
They always check us for dated seatbelts and helmets. Neutral safety switch a "must".
Everybody knows somthin.
Nobody knows everything !
Old 07-13-2022, 05:08 PM
Yes for helmet date. I use stock seat belts 12 second range. I remember 'old' tower,getting up next to starting line for pictures of wheelstands esp altered wheelbase 63 Lemans and Arnie s backups.
