Old 08-10-2022, 12:47 PM
jwhit jwhit is offline
Default 8.2 bop deck height
can any body prodvide what the deck height should be for the 3 differnt
carriers for 8.2 bop rear end i know you have to have correct carrier depending on gear size i want to use 3.55 gear so deck height for 3.36 carrier would be nice
Old 08-10-2022, 12:58 PM
Not sure I'd call it call deck height, but believe we're on the same page.
Can go out & measure the distance from base of LH carrier bearing to the ring gear flange
Old 08-10-2022, 01:10 PM
thats mearsurment i need from 3.36 carrier my car right now is 2.79 and i bought a set of 3.55 but need to find a carrier thats for 3.36 and higher i cant afford to buy new posi unit right now and if the distance is not to much i made cut a spacer ring ?
Old 08-10-2022, 01:24 PM
2.56 & 2.78 were used on the high ratio carrier.
2.93-3.08-3.23 mounted on the mid ratio carrier.
To mount a 3.55 ring gear, will need a low ratio carrier, or in a huge pinch you could run, the low ratio ring ger on a mid ratio 8.2 Pontiac carrier using a Mr G 8.2 ring gear spacer & lib amt of locktite on the bolt threads. On Pontiac 8.2 carriers, keep in mind, in late '69 model, at least on Bird rears the carrier & ring gear went to 1/16" diam larger diam ring gear bolts which are LH thread. All '70-72 8.2 Pontiacs used the late 8.2 Pontiac style carrier & oem ring & pinion.
Old 08-10-2022, 01:49 PM
With carrier bearings installed on a low ratio 4 pinion Pontiac 8.2 carrier, measuring from the bench up to the ring gear mounting flange,
2.05"
Old 08-10-2022, 02:08 PM
AG's Avatar
AG AG is offline
3 series (2.93-3.23) is about 1.85", 2 series is about 1.68".
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
Old 08-10-2022, 02:48 PM
THANKS
