63 Tempest engine / Tremec challenges
early block with early bell housing and starter to a late transmission
Wondered who has tried a early block pre 65 to a Tremec transmission? Tremec has no options, need a early bell housing. Using 389/421 block. Related question is the starter and header clearance. Going to be a challenge I know. Car is a 63 Tempest |
Will be interesting,the trans is tilted to the drivers side.The reason when I built my car 22 years ago I used a 428 block to have the block mounted starter.My 62 GP still has a 63 HO block with a 4 speed.Tom
Would this be the correct one? These two look like the same part number. Cast iron
https://www.ebay.com/itm/17531062399...is&media=EMAIL Or..... https://www.ebay.com/itm/22460338973...is&media=EMAIL
Hoping to finish a project while I'm still able to push the clutch in.... 1963 Tempest Convertible (195-1bbl, 3-speed transaxle. 428 RAIV, 5-speed, IRS planned) Pictures |
61-62 has a bushing for the H type Z bar.63-64 uses a threaded ball the Zbar slides over.From the view I can’t tell if 61-62 or 63-64.I think either can be modded to work on either.Tom
They are both 63-64 from the side view.Tom
