Body Problem Areas 69 Grand Prix
May be inspecting a 69 GP for potential purchase soon and owner says body has rust on door and a couple other areas (see pics). She claims trunk, floor pans, body/mounts are ok - of course I will verify and based on other pics I suspect issues. What should I look for in this model? Any known problem areas?
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears ‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded) '69 LeMans Vert, 350, #47 heads: Non-running project |
'69 - '70 Grand Prix
Oh Boy. That car appears to be one crusty critter. Not sure I'd want to take it on.
Parted a '70, Blue, southern NM car about 15 years ago. It was super rock solid except for a caved in Drivers' Quarter panel. The tub then went to azchevs to be cut up. Very savable car, by the right body man. But it went to various parties to help save their cars. Probably the same areas will rust, as other '68 - '72 A cars. Behind the rear wheels. The outer wheel house to Quarter lip. Bottom of the front fenders. Bottoms of inner cowl, where leaf and pine needle debris winds up. I'd look for a southwestern body, before fixing that one. |
Moderator - can you move this thread to the Grand Prix tech for me?
Looked at at car this morning- every panel minus the fenders had bubbling…definitely a crusty critter. The frame and body underneath was surprisingly clean.
Because the GP used a boxed frame like used on convertibles they also tend towards frame rot behind the front wheels. Otherwise they have the regular A body trouble spots; windshield and rear window channel rot (supercharged by vinyl top option), trunk pan and rear quarters and floor pans. The GP’s typically had less rust in the lower rear corners of the front fenders than typically seen on A body cars.
My Break Away Squad 1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops) 1969 LeMans (2dr & 4dr Hardtop and a Cvt) 1969 LeMans Safari 2 seat Wagon 1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop) 1969 Catalina (3 Cvt’s & a 2dr hardtop) 1969 Ventura 2 Seat Wagon 1969 Executive 4dr Sedan 1969 Bonnie Cvt 1969 Bonnie 3 Seat Wagon (2 of them) 1969 Bonnie Brougham (4dr Hardtop & Cvt) 1969 Grand Prix SJ (2 of them) 1969 2+2 2dr Hardtop (Canadian model) |
