301 head gasket on 350P
Hey all
Just checking, a local guy messaged me thats putting new heads (small chamber #15) on his 350P that came out with about 7.5:1 compression He said he had the heads on, but the valley pan gasket was too narrow....... Hmmmmmmm Turns out he had a 301 gasket set, or part of one anyway. He said he had to "modify" a few water holes in the 301 gaskets to line up........ Has anyone successfully run a 301 gasket on a std block. He said bore size was alot closer than the generic Felpro 4.30 which was good at least I know there can be issues when swapping std heads onto a 301, as missing ares in the block or something, but not sure on the other way round ??? I dont have 2 on hand to compare..... Thanks in advance
Working on going faster (and now staying dry at the same time !!) |
Well the water passages are in the same location on the 301 and there shaped a little different, but it should still work.
I do stuff for reasons. |
Don’t use a 301,order a correct 350 head gasket.You will have issues with the 301.Tom
The Following User Says Thank You to tom s For This Useful Post: | ||
