Old 10-26-2022, 08:57 PM
cnc's Avatar
cnc cnc is offline
Default Dash lamp socket
Single pigtail for one of my lights in the dash. Can this be stripped back for fresh wire and soldered back to the button.
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 10-27-2022, 12:34 AM
If you are careful it should be fine.
Old 10-27-2022, 01:02 AM
dataway's Avatar
dataway dataway is offline
Yep ... get in there and clean it the best you can and use plenty of flux ... and clean the flux off very well when you are done.
And ... for those folks that like to solder ... if you don't have one, do yourself a favor and get a Hako soldering station ... jeez it makes life easier having a proper soldering iron.
