Old 12-09-2022, 12:04 PM
robg8r's Avatar
robg8r robg8r is offline
Default Will Original headers fit?
I have a 69 Pontiac Lemans with a 350 in it. I removed the engine and put a mid 70s pontiac 400 (6X heads). I left the manifolds on the 400 because i intended to use them but now I want to use the headers. will the original headers from the 69 350 fit on the newer 400?
Old 12-09-2022, 12:35 PM
gtospieg gtospieg is offline
They should fit. Are the end holes in the heads drilled for the exhaust?
Old 12-09-2022, 01:02 PM
turbo69bird's Avatar
Yeah they should fit as long as you used the same motor mounts nothing should be any different but as suggested check for the header bolt holes.
960 HP @ 11 psi, 9.70 at 146.
