Old 12-10-2022, 03:26 PM
Rick Rick is offline
Default Ram air lower pan and Holley carb
Does any known if you can use a metal reproduction ra3 lower ram air pan with a Holley carb with vacuum secondaries without modifying the pan?
If not what mods are needed?
Old 12-10-2022, 05:37 PM
tom s tom s is online now
I have been using on my 69 bird,TA hood with no issue
Old 12-10-2022, 09:31 PM
turbo69bird's Avatar
Believe some have dimples for the Holley float adjuster screws and some do not.
960 HP @ 11 psi, 9.70 at 146.
Old 12-12-2022, 09:13 PM
Thanks for the feedback.
Old 12-12-2022, 10:51 PM
65madgoat's Avatar
Yes two versions exist for the Ram Air -4- pans for fitting a holley. But doublecheck for a Ram Air 3 pan as I do not know if the dimples were ever offered on them. Maybe Tom S can post pics of his set up that clears.....
Old 12-12-2022, 11:25 PM
Mine is a PartsPlace RAIV first gen lower pan.Will shoot a pic of carb side.Tom
Old 12-12-2022, 11:56 PM
65madgoat's Avatar
Yes. But he had asked about Ram Air THREE....
Old 12-13-2022, 12:13 AM
I don’t have a 3 lower pan,from the parts place picture I can’t tell if it has the dimples to clear the Holley .Tom
Old 02-12-2023, 07:40 PM
The metal reproduction ra3 lower ram air pan will clear a Holley carb with vacuum secondaries without modifications.
Thanks for the insight.
