EFI Tech All things EFI and making classics modern!
Old 01-26-2023, 12:04 AM
68WarDog's Avatar
68WarDog 68WarDog is offline
Default RPM signal
Since installing the Sniper EFI , I don't get a rpm signal to the hood tach from the dark brown wire, even after installation of a tachometer adapter. Is it possible to tap into the negative wire from the Holley hyperspark coil? I believe the gray wire from the coil is negative .
The Following User Says Thank You to 68WarDog For This Useful Post:
