Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 02-09-2023, 04:40 PM
Kevin Kevin is offline
Default Intakes For Sale
Offy Dual Quad 5499 all original and in great condition, I'm not sure it was every used. $400 shipped
Torker 2 - New 100% original comes with original Edelbrock throttle bracket and hardware. $350 shipped
Pro Comp EFI intake - New $175 shipped.
I have a new Performer RPM and an original 66 tri power intake coming too but I haven't got them dug out of the garage for pics yet. Feel free to PM me with any questions.
ID:	606954   Click image for larger version
ID:	606955   Click image for larger version
Old 02-12-2023, 09:36 PM
GTO nut GTO nut is offline
I would be interested in the performer rpm when it's available.
Old 02-13-2023, 12:53 AM
MidnightAuto's Avatar
MidnightAuto MidnightAuto is offline
I’ll take 2nd slot on rpm. Is the tripower original or aluminum aftermarket?
Old 02-13-2023, 01:00 AM
jspeed's Avatar
jspeed jspeed is offline
Default tri-power
I;ll get inline for the tri-power...
Old 02-13-2023, 01:38 AM
wbnapier wbnapier is offline
Are 66 and 65 tri-power intakes interchangeable? Or do you need an adapter for the middle carb flange?
1965 Pontiac GTO
455/469 w/ #48 Heads, '65 Tri-Power
9.25:1 CR
Stump Puller Cam
Muncie M22W 1st-2.56 2nd-1.75 3rd-1.37 4th-1.00
3.55 Rear Differential
Front: 225/60R15 Height: 25.6"
Rear: 275/60R15 Height: 28"
Old 02-14-2023, 09:16 AM
I will get the RPM intake dug out today. It is still in the original box. Same price as the T2 $350.
The tri power is an original 66. BUT the coolant crossover was cracked and has been welded around the temp sensor. It would be good for someone who has a separated coolant crossover or the temp sensor hole will need to be redrilled and taped. It will be a couple days before I can get it dug out to get pics.
Old 02-15-2023, 10:41 AM
Here is a pic of the RPM intake for those interested.
The Following User Says Thank You to Kevin For This Useful Post:
Old 02-17-2023, 12:19 AM
Default performer rpm
I'm interested in your rpm manifold and sent to a private message. Thanks
Old 02-17-2023, 11:58 AM
jspeed's Avatar
Default tri-power
I'm out on the original tri-power... thanks
Old 02-20-2023, 02:56 AM
Hey Kevin ,I'll take the performer rpm. How do you want to get paid.
Old 03-01-2023, 12:51 PM
Here is a pic of the tri power intake. It needs some TLC. The right side temp sensor port has been welded and needs drilled and tapped. One carb stud hole in the center pad needs to be repaired as well. Asking $100 + shipping.
Name:	66 intake.jpg
Old 03-01-2023, 01:07 PM
433lemans's Avatar
433lemans 433lemans is offline
PM sent about tripower intake
Old 03-05-2023, 03:52 PM
Tri Power intake is gone. The others are still available. I'm open to offers.
