I overlooked this needed part. I am swapping out my tripower for a quadrajet on an RPM.
The throttle bracket is incorrect. Any suggestions? Those universal kits are kinda ugly. I would like to avoid them if I can. Sent from my SM-A136U using Tapatalk
........I'm just learning as I go....... |
I like the Lokar cable however agree it’s not correct for some cars but you can cover it w shrink tube too.
I have cut a factory throttle cable bracket and welded it to a plate across the two bosses on the edelbrock intake for factory cable useage I can get pic tomorrow nothing fancy but it worked fine
1969 carousel red firebird 455, richmond 5 speed 1964 540 gto 1971 lemans sport convertible 1972 Maverick under slow construction |
https://forums.maxperformanceinc.com...d.php?t=795417
This thread has some pictures and information that might be helpful.
The Following User Says Thank You to b-man For This Useful Post: | ||
Thanks everybody.
Ames has a part for this. I found it at random this morning. Hope this helps someone. I will do a follow up once its installed. https://secure.amesperf.com/qilan/De...A&web_access=Y
The Following 2 Users Say Thank You to Rugratman For This Useful Post: | ||
Color me cheap but, $115.00?
Here is what I used: '71 Chevelle Qjet Throttle cable bracket ($26.00). Pictured upside down showing anti-rotation pin that engages Qjet baseplate at corner and '68-80 GM throttle cable retainer split lock ($7.24) to retain cable. ![]() ![]() As installed it looks and functions like OEM. The Spreadbore carb mounting is same as a Qjet including bolt location and anti-rotation hole. If your Qjet uses a raised "bump" instead of the anti-rotation pin, you simply drill out the pin on the bracket which is just staked on. Note factory style return spring location as well. ![]()
Triple Black 1971 GTO |
I think I also found a Chevy part on a pickup truck in a junkyard, although I believe I needed it for the TH350 kickdown cable. Amazing the things we now wish we had grabbed by the bucketload when they were plentiful in junkyards in the 80s/90s.
Mike ![]() |
The Following User Says Thank You to mzbk2l For This Useful Post: | ||
Update finally installed the kit.
Overall it's a great kit. Fit like a glove. I used my tri power cable and the length was correct. But it is maxed out. Nice thing is, you have adjustments side to side and front and back. The bolt holes lined up perfectly. T6 aluminum is very sturdy. I am toying with the idea of painting it black though. Kinda shiney. Hope this helps someone in the future. See pics. Sent from my SM-A136U using Tapatalk
Sorry tapatalk won't let me load pics
Will try later. Sent from my SM-A136U using Tapatalk
Here is one
![]() Sent from my SM-A136U using Tapatalk
One more
Have you looked at these guys, had one on my Catalina and looked great and worked perfectly. http://precisionspecialists.com/inde...tml&lang=en-us
