Tri-Power Tech 57-66 Tri-Power Talk
Old 02-23-2023, 09:22 PM
drewm drewm is offline
Default 1957 - 1966 Tri-Power Jet Sizes
Did a google search, but no luck. Anyone know what size jets would have originally come in a 66 tripower, manual trans? I just started working on my tripower and was just curious if anyone had done anything in the past. Opened up the end carbs, and they have 68's. Haven't looked at the center carb yet.
Drew
Old 02-23-2023, 10:11 PM
You didn't say what car so here's both. T/8, P/8 pn: 7008668 front and rear
T/8 pn: 7008661 center
P/8 pn: 7008662 center
Last 2 digit are the jet sizes.
The Following User Says Thank You to Goatracer1 For This Useful Post:
Old 02-23-2023, 10:26 PM
I forgot, its a GTO. And thank you for the answer.
Old 02-24-2023, 05:00 AM
Kenth's Avatar
Kenth Kenth is offline
1966 T/8 389 cui M/T and P/8 421 cui M/T uses the same 7026075 center Tri-Power carb with #62 jets.
1966 T/8 389 cui M/T with A.I.R. uses the 7036175 center Tri-Power carb with #61 jets.
1966 T/8 389 cui uses #68 jets in outer carbs, and 1966 P/8 421 cui uses #73 jets in outer carbs.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 02-26-2023, 03:29 PM
Dick Boneske's Avatar
This should be a sticky. Here are all the Pontiac Tri-Power jet sizes.
Name:	Tri-Power Jet Sizes.jpg
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 02-26-2023, 04:28 PM
Kenth's Avatar
All Pontiac Tri-Power carbs uses #70086xx 60° Approach (Long Taper) jets, except 1957-58 end carbs and 1965 421 A/T center carbs.
1957-58 end carbs and 1965 421 A/T center carbs uses #70026xx 60° Approach (Short Taper) jets.
Name:	Tri-Power Jet Style.jpg
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
