Old 03-05-2023, 11:22 AM
getmygoat's Avatar
Default Surging at idle
Hi all,
I have a '69 GTO that just got back from restoration.. has been sitting for 2 years... Original Rochester carb was rebuilt by Paul Spotts (he sends them out) 10 years ago. Only about 150 miles on the car total since then. Engine was rebuilt a few years ago by gtofreek.
Car is surging somewhat at idle. I'm not very skilled with carbs... was wondering are there some basic things to check for this? I've read vacuum leaks (unlikely - maybe the brake booster?).
Thanks!
Old 03-05-2023, 01:10 PM
Kenth's Avatar
Kenth Kenth is offline
Some things to look into:
ID:	608364   Click image for larger version
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 03-05-2023, 04:30 PM
25stevem's Avatar
25stevem 25stevem is offline
The first thing you want to do with the motor idling is confirm that the boosters in each primary are not dribbling fuel, if so you really want to run the motor as little as possible so you do not wash out the rings and cylinder walls.
If it’s surging from being lean while that is a problem at least your not killing the motor..
I do stuff for reasons.
Old 03-06-2023, 06:30 PM
trishieldchief's Avatar
Your primary rods spring is too light, put a heavier spring in and surging will stop.
Rich Johns
www.purestockauto.com
1970 GSX Stage 1 Auto 3.64 # 603 of 678 12.44@109.73 mph 2011 Buick GS Nats Pure Stock, 12.71@110.64 mph PSMCDR 2011
1970 GS Stage 1 Convertible Auto 3:64 12.71@109.15 mph PSMCDR 2009
1970 GS 455 M21 4 Speed 3.42
1987 GN Astro Roof
Old 03-06-2023, 06:41 PM
John Milner's Avatar
John Milner John Milner is offline
If your car has hideaway headlights with new actuators, the upper seal in the vacuum actuator can wad up when operating the headlights and cause a vacuum leak. Easy enough to check, just temporarily plug your vacuum source for the hideaways and see if the idle clears up.
Old 03-07-2023, 07:15 AM
25stevem's Avatar
With the motor fully warmed up and at idle it's easy to check if the condition is from being lean, all you need to do is close off the Choke flap little by little to see if that richening up helps stabilize the idle or makes it worse.
To do this you will likely have to pull off the vacuum source to the Choke pull off and plug that vacuum line with a small bolt or machine screw .
