Old 03-11-2023, 03:51 PM
Red Box Rebel Red Box Rebel is offline
Question 69 to 68 Ram Air Flapper Door
Very simple Question:
Is it possible to add a '69 Ram Air Flapper door on the '68 Ram Air Hood pan using '69 open scoops?
Old 03-11-2023, 08:00 PM
Scott Thelander's Avatar
with a little under hood trimming
The Following User Says Thank You to Scott Thelander For This Useful Post:
Old 03-12-2023, 12:49 PM
Question
Exactly how much is a little and where should you trim? Anyone with pictures of how to and/or videos?
Old 03-15-2023, 01:02 PM
gto4evr gto4evr is offline
not sure it would work with a 68 upper pan, I'd think you'd need to use the 69 upper pan. There's pics I know I've posted years past but don't feel like searching!
here's a pic of the templates they sell to show where to cut the braces if you're not winging it.
Old 03-19-2023, 01:22 PM
Thank you for the reply. I have a Metal '68 upper pan and do not want to switch to a '69 upper pan. That is the reason for inquiring into whether there is a way to use the '69 open scoops with the '68 upper pan and the '69 flapper door set up.
Slight mods are reasonable, but I do not want to simply switch to a full '69 upper and lower pan set up.
The Following User Says Thank You to Red Box Rebel For This Useful Post:
Old 03-28-2023, 12:01 PM
I just happened across this older thread where I posted pics on where the brace cuts were when I added the RA to my 69.
https://forums.maxperformanceinc.com...d.php?t=843373
see post #7. I don't see any reason to cut the brace back that far for the addition of the flapper doors. the bracing needs to be cut back that far only to accomodate the 69 pan. if you cut just a small bit out of the edges for the flapper, I think you can still cover it with the 68 pan and have what you're looking for.
The Following User Says Thank You to gto4evr For This Useful Post:
