Drivetrain Compatibility between Years
Could I please have comments regarding interchangeability of suspension and powertrain components between the three years? I have read that the rear swing arm geometry was changed for '63? Will any year transaxle bolt in the rear suspension subframe of other years? Are all driveshaft/tubes the same length? I know the driveshaft diameter was different depending on engine and transaxle? Again, I know the front subframe "K-member" needs to match the engine, but are they interchangeable between years? Any help would be appreciated so that I can answer questions about the parts I have for sale.
Hoping to finish a project while I'm still able to push the clutch in.... 1963 Tempest Convertible (195-1bbl, 3-speed transaxle. 428 RAIV, 5-speed, IRS planned) Pictures |
61 and 62 can interchange. 63 is 2 inches wider than the 61 or 62. Driveshafts and torque tubes vary by year, engine, and transmission. If you are a Little Indians member they have a listing of all driveshafts and torque tubes by year, engine, and transmission in the tech section of their web site. www.littleindians.com
If you built it, drive it. red 62 Tempest total stock restoration. white 62 Tempest modified, 61 389 Tri-Power, and a conventional drive train. |
