Tool shopping.
I think I am going to need a bigger Torque wrench for these main cap bolts!
The Following User Says Thank You to steve25 For This Useful Post: | ||
I have quite a few pictures of that engine somewhere on my computer.
Tom V.
Wow. Wonder if you can remove balancer bolt with just hitting starter? I know.
The Following User Says Thank You to sdbob For This Useful Post: | ||
Hazzard Fraught has a coupon... |
I will have to rent a pick up truck from Home Depo to get the new Torque wrench I buy from Hazzard Fraught back home.
Girdle dowel pins are far away like along the pan rail. Main Caps are double-Stud per side which is nice.
The Following User Says Thank You to Half-Inch Stud For This Useful Post: | ||
Get one of these. Makes big jobs look like child's play.
Triple Black 1971 GTO |
You can make a coffee table out of the plasti-gage they use to check the bearings.
I'm World's Best Hyperbolist !! |
The Following User Says Thank You to dataway For This Useful Post: | ||
If I was there I would be worried about falling into the Bearing clearance gap and never being found!
Engineer, now with the kung-fu grip!
The Following User Says Thank You to chiphead For This Useful Post: | ||
Note that the hoses in that photo are going into his Chest.
I would then guess that the machanics where hydro.
Hope their not using Chinese lifters for the cam break in…..
Hopefully you can change the rear main seal without removing the crank.
