Old 04-14-2023, 11:07 PM
TA63 TA63 is offline
Default dual exhaust crossmember for 77
Does anyone offer a transmission crossmember that will work with a dual exhaust on a 77 grand prix with TH400?
Old 04-15-2023, 10:12 AM
brewcitybirs brewcitybirs is offline
Any 1973-74 gm a-body except El Camino should work. If you search 1973-1977 GM A-body cross member for what ever reason it doesn’t list Grand Prix. I have a 75 GP and I used a crossmember from a 73 Lemans.
1975 Grand Prix
1959 F100
Old 04-15-2023, 02:55 PM
https://www.crossmembers.com/product...ember-hardtops This one would work.
1975 Grand Prix
1959 F100
Old 04-18-2023, 12:42 AM
Thank you!
Old 04-18-2023, 12:48 PM
GNvsTA GNvsTA is offline
If memory serves, its been awhile, I used a LeMans crossmember on my 77 GP also.
78 Firebird Formula-Cameo white
98 Trans Am-Arctic white
77 Grand Prix SJ-Brentwood brown met
Old 04-27-2023, 10:25 AM
It might work, but if I remember correctly the 73-77 G bodies used a tubular cross member, and the 73-77 A bodies uses a flatter stamped cross member. I may still have the cross member I pulled out of a 73 GP a few years ago in storage. I will try and remember to look for it this weekend.
Old 04-27-2023, 11:15 AM
From my understanding the difference was the transmission. The flat stamped piece was for Turbo 350's the tubular was Turbo 400. They both work with either trans. My crossmember is from a 73 LeMans that had a Turbo 350, my GP has a turbo 400 I used the stamped style. Basically all the 2 door GM Colonnade bodies are the same from the firewall back. Did the same thing on my step bro's 74 Cutlass, removed a 350 Turbo 350 installed a 455 Turbo 400 used the stamped Turbo 350 crossmember just had to move the crossmember back to the rear holes in the frame.
1975 Grand Prix
1959 F100
The Following User Says Thank You to brewcitybirs For This Useful Post:
Old 04-28-2023, 11:08 PM
Thanks! I'd be interested in it if you wanted to get rid of it.
Old 04-29-2023, 04:49 AM
If I still have it I would be willing to sell it, where are you located? Shipping will probably be expensive due to its size.
Old 04-29-2023, 08:01 PM
redonred81 redonred81 is offline
If still available im interested in it.thanks
Old 04-29-2023, 11:25 PM
I'm in South Dakota, and am used to being beat up on shipping haha. It's gotten especially bad the last few years it seems. Gotta pay to play!
