Old 04-18-2023, 02:45 PM
gtobird's Avatar
gtobird gtobird is offline
Default Fuel Pump Bolts?
Folks,
Did Pontiac use washers from the factory on the 12 point factory bolts for mechanical fuel pumps? If so, what kind? The last time I replaced a fuel pump, I didn't use washers. I just put some sealer on the bolt threads.
Old Joe
68 Firebird Convertible
68 GTO Clone (Tempest) Wagon
Old 04-18-2023, 03:25 PM
OG68 OG68 is offline
Mine had rubber coated flat washers.
2007 Cadillac SRX
Old 04-18-2023, 03:55 PM
steve25 steve25 is offline
Factory fuel pump bolts are not 12 point.
Old 04-18-2023, 04:06 PM
Some of them were 12 point. I have several here that up pulled from salvage yard engines.
The factory did use a special sealing washer at least on some.
Old 04-18-2023, 04:37 PM
gtobird's Avatar
I've got (3) 68 engines and all of them have the same 12 point heads on the bolts, so I'm guessing they were correct for 68. That said, only one of them had washers and those were just ordinary hardware store washers. I read somewhere else that Pontiac had rubber coated washers on the fuel pump bolts, but not sure if it was all V8 engines or just certain years.
Old 04-18-2023, 05:14 PM
I've got a '66 389 that had the 12 pt bolts.
Old 04-18-2023, 05:19 PM
grandam1979 grandam1979 is offline
Any pictures of these 12 points? I would like to see the 68 bolts I have never seen one on a 60’s engine.
Old 04-18-2023, 06:19 PM
From my 68.
ID:	610998   Click image for larger version
ID:	610999   Click image for larger version
2007 Cadillac SRX
Old 04-18-2023, 06:32 PM
gtobird's Avatar
From my 68.
I looked at one of the sets of bolts I have from my 68 and they are identical including the head marking. Did yours come with washers? If so, got a picture of those?
Old 04-18-2023, 06:42 PM
From my 68.
Thanks for the pictures I have never had a 60’s engine with those I’m going to look at my bolt collection maybe I just missed that one.
Old 04-18-2023, 06:56 PM
I have never seen such in all many Pontiac motors I have ever had or disassembled!
Old 04-18-2023, 07:05 PM
No washers handy. I have all my leftover nuts and bolts in about 10 Folgers cans.
I bought a replacement set from our sponsor.
Pg 196 in current catalog
https://secure.amesperf.com/qilan/De...A&web_access=Y
2007 Cadillac SRX
Old 04-18-2023, 07:08 PM
gtobird's Avatar
From my 68.
Ames lists these bolts for 64-68 engines. If you only had newer engines, perhaps that was it (or of course they were long disgarded by a non-original type person). Nahhhhhhhhhh that person couldn't be. LOL
Old 04-18-2023, 07:14 PM
gtobird's Avatar
You are the man!!!!! Did you order just the washers, or the bolts with washers? If it was bolts with washers, were the washers rubber coated?
Thanks again
Old Joe
Old 04-18-2023, 07:54 PM
Scott65's Avatar
Scott65 Scott65 is offline
They are 3/8" I believe and wouldn't work in the later 5/16" holes. Dad's 65 GTO has the same fasteners as pictured.
Old 04-18-2023, 08:43 PM
rwfisher's Avatar
rwfisher rwfisher is offline
These were pulled off an early 1968 YS engine. They are larger as indicated, 3/8”. They originally had steel washers that had rubber encapsulated on one side. Unfortunately they were deteriorated and I discarded them.
Old 04-18-2023, 08:47 PM
rwfisher's Avatar
These are standard ARP replacements.. Not exactly as originals but an excellent 12pt bolt..
Old 04-18-2023, 08:58 PM
rwfisher's Avatar
The ones I removed were similar to these.
Old 04-18-2023, 08:59 PM
Thanks again
Old Joe
Just the washers. The bolts came with the ADK engine kit. When it came time to assemble the engine I couldn't find the washers so ordered them from Ames.
At least I think I did... Its been a few years.
2007 Cadillac SRX
Old 04-18-2023, 09:15 PM
rwfisher's Avatar
Found these pics on the web of what the originals looked like. Again these would have been for the earlier timing cover.
AMK also offers excellent replacements for the bolts and washers…
ID:	611015   Click image for larger version
