New Dyno Numbers
Dyno days are usually fun, so thought I would post my latest tweaks... Some thought I was a little crazy tearing down a perfectly strong running motor, but winters are long in MN and the trans needed to come out anyway. And this particular winter does not want to end!!!
For comparison, five years on original build with around 500 drag runs and handful of street miles. Specs in my signature, which at the time ran 585hp on the dyno, but was definitely running stronger with additional tuning and intake porting over the years. Lets estimate 595-600. I picked up the attached solid roller cam from a fellow member and had the heads opened up to around 325-330cfm and upgrade springs as needed. Running the same worked T2 intake w/2" open spacer. Best HP at 35-36 deg timing. On a side note, bearings and cylinders looked like new on tear down, so this was essentially done for entertainment purposes and a few extra horses. Threw in a new set of bearings, used a dingle ball hone on cylinders and installed the SD Performance lifter bore braces. Attached is a run using my 1.75" Hedman headers and a run using Darbys 2" headers with adapter plates. I am happy with results and looking forward to seeing the on track results! Sent from my SM-G965U using Tapatalk
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight |
The Following User Says Thank You to leeklm For This Useful Post: | ||
Great new numbers !
What compression is the motor? Some observations. Your old combo used 308 cfm to make that 635 Hp. Your new combo used 311 cfm to make that 641 hp, so you pretty much have the heads tapped out now. That being said I think the main improvement came by means of the 2” headers allowing a 4 to 5% increase in peak exh flow numbers. I bet the 1.750” headers matched your exh port flange area very closely, so the bigger 2” tubes then not only helped to increase the flow by means of pressure recovery, but they helped with reducing reversion. This action can be seen in the near 20 ft pound gain in torque down at 4100 rpm over the 1.750” tubes. You can also see the reduction in reversion between the two down at that same 4100 rpm in the fact that the BSFC numbers are just about the same. Although the test did not go below 4100 rpm if it did you would see that the new combo will have much more torque and throttle response on the street. From the massive amount of rework I have done in the passed on T2 intakes I can tell you that with your 2” headers and intake flow numbers now that the T2 your running is now the cork in your overall flow tract . If you where looking for more Hp a 1050 Dominator, even used with your T2 would give you 12 to 15 more numbers up top. Springs finally here, enjoy having a heavy right foot!
Wernher Von Braun warned before his retirement from NASA back in 1972, that the next world war would be against the ETs! And he was not talking about 1/8 or 1/4 mile ETs! 1) 1940s 100% silver 4 cup tea server set. Two dry rotted 14 x 10 Micky Thompson slicks. 1) un-mailed in gift coupon from a 1972 box of corn flakes. Two pairs of brown leather flip flops, never seen more then 2 mph. Education is what your left with once you forget things! Last edited by steve25; 04-21-2023 at 06:14 PM. |
The Following User Says Thank You to steve25 For This Useful Post: | ||
Thanks Steve,,
compression at 10.5, running BP 93 0ctane. I am somewhat stuck with the 1.75' headers, as it looks like a real pita to find or make 2" dport headers for a 1st gen. I think that will be ok, as I may be flirting with the 10.0 mark on good air day. Running full exhuast, etc at Norwalk last year I was running a consistent 10.4 with the old faithful cam. Best prior et with open headers was a 10.29 in good air. My guess for the new combo is a 9.99 for that end of year hero run. I may be bolting lead in the trunk lol. I have zero desire for a certified cage and the other goodies at this point. Sent from my SM-G965U using Tapatalk
Great job! Stout numbers!
The Following 2 Users Say Thank You to PAUL K For This Useful Post: | ||
That's great!! Thanks for sharing
The Following User Says Thank You to slowbird For This Useful Post: | ||
Your cam is close to the one I had reground at Bullet. What is you CR ? |
The Following User Says Thank You to Dragncar For This Useful Post: | ||
Looks like 10.1 ET using 3300# and 636 Hp. Your cam is a tiny bit bigger than mine.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
The Following User Says Thank You to AG For This Useful Post: | ||
Nice gains, you should be knocking at the 10.0 numbers.
The Following User Says Thank You to Scott Stoneburg For This Useful Post: | ||
Well done. I am sure you will be pleased with your next trip to the track. And your engine combo is very similar to mine so I have high hopes for my first all out assault on the 1/4 mile in a week or two. My Lunati cam is very close to the Bullet that you have and like you I am running 1&3/4 headers. I do have the Northwind intake ported to match the KRE 325 heads. The 8 point roll bar is almost done so I should have some numbers after our next test and tune. Best of luck with your 'new' engine.
69 Bird w/1970 400 block(409 cubes), #64 heads, hyd. roller, Q-jet by Jeff E., original interior, ps, pdb, th350, and 3.73 gears. Pump gas, street driven muscle. 3800 lbs. race weight. Best, 11.39 @118, my son's car. 79 T/A w/463, Scat crank, Eagle rods, Icon pistons, Lunati solid roller, 262/270, KRE 325 heads, Northwind intake, QF950 carb, full interior, ps, pdb, th350, and 3.73 gears. Pump gas, 3650 lbs. race weight. 10.68 @ 126 so far... no tuning yet. |
The Following User Says Thank You to prostreet64 For This Useful Post: | ||
Great job! those are some Stout numbers for 10.5 compression!
Jim Moshier 1971 Grand Prix 462ci SD Performance 6x heads 1962 Catalina 389 1968 Firebird 400-455 I haven't decided "If we ever forget that we're one nation under GOD, then we will be a nation gone under." - Ronald Reagan |
Play with the valve lash, if you get a chance.
I had solid roller from Bullet in the 427 SBF I built 12 years ago. It also called for 0.026"/0.026". I tested on a chassis dyno. Started with the intake lash, and found the motor ran best with 0.021" lash. Then tested the exhaust, it liked 0.024" Compared to 26/26, the 21/24 gave me 16rwhp at peak, and picked up 25rwhp in the midrange (around 4500rpm). Your results may vary :-)
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust |
The Following User Says Thank You to Lee For This Useful Post: | ||
Ignore my ignorance, this was on an engine dyno correct?
I assume this because of the info shared on parts that would make the most sense since.. Dynojet is roughly 11% reduction (then converter slippage) Mustang roughly 16% (then converter slippage) Your numbers would be like... 689hp/713tq at the engine if your sheet was taken off a Dynojet. Killer anyway you slice it.
69 GTO Convertible, 4000lbs 462ci, 606tq/569hp - 93 oct at 34 deg (207psi) 11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10" 0 Stat, Ricks SS Gas Tank, Magna 4303, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" Headers & Borla Pro XS 3" Muffs, Alum Rad & Dual Fans, 12:1 Box, UMI Control Arms & Viking Berz Fr + Rear CO Shocks, Hella UP28 Vac Pump |
Engine dyno is correct
Nice
We have a similar combo except your bigger Old Faithful 2.0 cam, interesting, you're at least 30hp more vs my as cast high port and Voodoo cam.
69 GTO Convertible, 4000lbs 462ci, 606tq/569hp - 93 oct at 34 deg (207psi) 11.7:1, KRE H Ports, Lunati HR 282/290 w Johnson Lifters & 1.65 Scorp, E30, EFI, Holley HP + Dual Sync, 12-1 Crank Trig, 120lb Inj & 1000cfm TB, Torker II EFI Int & Rails, PTC 10" 0 Stat, Ricks SS Gas Tank, Magna 4303, Aerom EFI Reg, Aero Front & Wilwood Rear Disc Brakes, Dougs 1 7/8" Headers & Borla Pro XS 3" Muffs, Alum Rad & Dual Fans, 12:1 Box, UMI Control Arms & Viking Berz Fr + Rear CO Shocks, Hella UP28 Vac Pump Last edited by GOAT8U2; 04-26-2023 at 04:28 PM. |
Double post??
Ya converter and drivetrain can be easily 16% on Dynojet and my local Mustang Dyno saw a 26% on an auto with slipping converter. Luckily my PTC 10" 0 blade is 3.5% slippage.
Great numbers, I'm doing 2 dyno mod tests to get to a hair over 600hp soon, I'll post back as I think there's 3% hiding in all our combos with these 2 mods rarely no one has.
