Old 06-04-2023, 02:19 PM
sixty8ragtop's Avatar
sixty8ragtop sixty8ragtop is offline
Default WTB Stock 1966 GTO Exhaust Manifolds
I’m looking to purchase a set of stock ‘66 GTO exhaust manifolds with decent seal surfaces.
1965 2+2 Convertible 421 HO 4-spd 3x2 8 Lugs
1968 GTO Convertible 400 AC Bench Seat Column Shift - Sold
Old 06-04-2023, 09:23 PM
gtospieg gtospieg is offline
Are you looking for correct dates or just manifolds that fit 66?
Old 06-05-2023, 04:33 AM
Stock 1966 GTO manifolds with reasonable wear of mounting surfaces is my goal. What exhaust manifolds do you have available for sale? Thanks..
Old 06-05-2023, 02:44 PM
I'm pretty sure I have a useable set somewhere in the barn. However shipping on such heavy items will be expensive...I'm in 12603 NY.
Old 06-05-2023, 03:10 PM
I've got a pair that I would probably part with. They came with a '66 WT 389 4-spd GTO engine. Pretty crusty but mounting surfaces are smooth. Heat riser is free. Biggest problem is that one of the flange bosses is broken on the one without the heat riser. Someone was using a flat washer under a nut to seal it there.
The other thing is I'm still in recovery from major stomach surgery so might be a little slow getting things done.
Just in case you can't find any you like.
Old 06-05-2023, 11:10 PM
Looks like I sourced a set locally.. Thanks to all who responded to my post.
The Following User Says Thank You to sixty8ragtop For This Useful Post:
