Old 06-05-2023, 09:41 AM
Ramairnacho Ramairnacho is offline
Default 1971 trans am hood
My friend Luis in Florida needs help.decoding stamp readings on bottom side of his original ta hood. Can anyone help us figure out what they mean.
ID:	613766   Click image for larger version
ID:	613767   Click image for larger version
Old 06-05-2023, 11:24 AM
GTO.PAUL GTO.PAUL is offline
Default Hood Dates
Those are May 12th and May 16th. The letter characters I have not been able to figure out, maybe stamping machine, shift etc? The rear bumpers and front fenders also have this same sequence for dating where applicable. Paul
The Following User Says Thank You to GTO.PAUL For This Useful Post:
Old 06-09-2023, 07:27 AM
Andy70RA3 Andy70RA3 is offline
Send a message via MSN to Andy70RA3 Send a message via Yahoo to Andy70RA3
Where is the date stamped on the fender?
70 white TA RAIII
70 blue TA RAIII
72 white TA
72 formula 350 (my first car)
Old 06-09-2023, 09:35 AM
Default Date Stamps
I have not looked at all year Bird and GTO fenders. What I have seen is on '69 Birds, the stamp is buy the front on the vertical engine compartment side, usually by the spot welds. On the '68/'69 GTO it is also on the engine side of the vertical portion spot welded to the outer fender but it is about 10" back from the front edge. Same can be said for the '65 GTO. '71 GTO has it on the horz lip by the hood hinges. Paul
Old 06-09-2023, 04:02 PM
Held for Ransom's Avatar
https://forums.maxperformanceinc.com...d.php?t=766288
So long, farewell.
