Old 07-06-2023, 02:31 PM
rasilverbird rasilverbird is offline
Default Neutral safety switch hookup - T56
Any of you guys hooked this up with a T56 trans? I would like to hook it up to the clutch pedal so that the car won't start unless the clutch is pressed in. Any ideas?
1968 GTO - 400/400 - Currently being rebuilt - 455/T56
1996 WS6 - LTI M6 - Sold 5/11
1979 Trans Am - 403/Auto - Sold 12/18
Old 07-06-2023, 03:20 PM
johnta1 johnta1 is online now
The 2nd gen Birds had a clutch pedal switch something like the brake switch is on brake pedal?
Should work good.
Old 07-07-2023, 08:10 AM
Should work good.
Thanks, I'll check out the fbody parts book to see if I can find it.
Old 07-07-2023, 09:10 AM
XLR8STEVE's Avatar
XLR8STEVE XLR8STEVE is offline
I hooked up the stock clutch switch on my 70 GTO to the starter circuit as it would be wired with any manual trans. It mounts on the pedal assembly. I have a T56 also but which type doesn't matter. I also added a snap switch on the floor to control the 2 step.
[SIGPIC]
Steve
