Old 08-23-2023, 06:48 PM
Tim Corcoran's Avatar
Tim Corcoran Tim Corcoran is online now
Default Comp Cams Evolution Lifters
I am asking for a report from people who are using the new Comp Cams Evolution cartridge style hyd roller lifters.
Tim Corcoran
Old 08-23-2023, 08:43 PM
tom s tom s is offline
Just got mine but the engine is not that far along.I bought a couple Xtra cartridges for mine just incase
Old 08-23-2023, 08:58 PM
AG's Avatar
AG AG is offline
I recently used them in a 455HO '71 GTO and was impressed with them. The adjustment felt the same for all the lifters and they were very quiet from the initial start-up.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule.
The Following 3 Users Say Thank You to AG For This Useful Post:
Old 08-23-2023, 09:00 PM
AG's Avatar
AG AG is offline
I've used the older CC857 from around 2011 and they were fine and used the newer CC857 and had a nightmare with them.
Old 08-23-2023, 09:21 PM
I'm only concerned with the new Evolution lifters, thanks
Tim Corcoran
The Following 2 Users Say Thank You to Tim Corcoran For This Useful Post:
Old 08-24-2023, 07:31 AM
AG's Avatar
AG AG is offline
Just giving my experience with the previous CC857 lifters compared to my experience with the new Evolution lifters.
Old 08-25-2023, 01:21 AM
lust4speed's Avatar
Rather frustrating. The Evolution lifters have been out for quite awhile now but haven't seen reports on them - either good or bad.
Mick Batson
1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 2+2 survivor AC auto -- 1965 Catalina Safari Wagon.
Old 08-25-2023, 07:07 AM
AG's Avatar
AG AG is offline
Here is a positive report.
Old 08-25-2023, 07:19 AM
Formulajones's Avatar
If you haven't seen bad reports then I'd say your good to go because rarely will you see a good report on the internet, everyone is more quick to bash something it seems.
It would be such a small sample size on this forum anyway.
I wouldn't be afraid to try them Tim. I'm using a set on the next build that's waiting for me after I finish the current build.
https://youtu.be/XqEydRRRwqE
Old 08-25-2023, 08:24 AM
Lee's Avatar
Lee Lee is offline
I've got about 30 minutes run time on a set, but just on the test stand. Have rather quiet mufflers to use with the stand, and no lifters noise so far. The motor is now in the car, and I've just started wiring the EFI system and have some other wiring to do. Hopefully have the car in the muffler shop within a couple of weeks, then can evaluate more thoroughly.
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
The Following User Says Thank You to Lee For This Useful Post:
Old 08-25-2023, 11:32 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Lee I think Joe ordered a set for the cam you are doing for his RAIV headed motor. I'll still bet you a single pattern or reverse split would work better
Skip Fix
Old 08-25-2023, 06:19 PM
Are you saying the new Evolution lifters have the same part number as the old style lifter?
Tim Corcoran
Old 08-25-2023, 09:35 PM
AG's Avatar
AG AG is offline
No, the quote here shows my first post that you might have missed regarding my opinion about my personal experience with using the CC new Evolution HR lifters. I posted a second one to offer a comparison with my experience with the previous two generations of CC857 HR lifters.
The Following User Says Thank You to AG For This Useful Post:
Old 08-26-2023, 09:20 AM
Evolutions have a dif part number.Butler has them on their site.Tom
Old 08-27-2023, 12:04 AM
Thanks for the clarification sometimes I get lost reading posts from different people but I got it now. Thanks for posting
Tim Corcoran
Old 08-27-2023, 08:49 AM
AG's Avatar
AG AG is offline
I wouldn't hesitate to use them.
Old 08-27-2023, 04:21 PM
I have Johnsons in there now and to my surprise they do make a little noise on occasion but seem to be getting better. I will see how things go if I am unhappy with them I may upgrade to the Evolution's.
Tim Corcoran
Old 09-23-2023, 02:22 PM
Lee's Avatar
Lee Lee is offline
100 miles on the Evolutions that I mentioned above, so far so good.
Old 10-24-2023, 01:36 PM
grivera's Avatar
grivera grivera is offline
Did the Evolution lifters require generally the same pushrod length you're accustomed to? Also, what is the recommended preload for them?
Will Rivera
‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded)
Old 10-24-2023, 05:49 PM
AG's Avatar
AG AG is offline
The motor I used them in previously had Lunati HR lifters and the body height of the CC Evolution where the PR sits was lower so I remeasured PR length and had to get new ones.
