Tri-Power Tech 57-66 Tri-Power Talk
Old 08-24-2023, 05:47 PM
mike w mike w is offline
Default KRE tripower intake horsepower and torque numbers Holley and Rochesters
Jeff Kauffman sent me these numbers today. I had supplied KRE with a set of Rochesters modified by opening up the Venturi area on all three to 1 3/8"
Motor was a 461 Pontiac with KRE heads, running pump gas and a hydraulic roller cam.
Holleys...641 HP and 575 torque
Rochesters...607 HP and 561 torque
fuel/air ratios very similar
Old 08-24-2023, 10:57 PM
Dick Boneske's Avatar
Dick Boneske Dick Boneske is online now
Thank you. Were the Holley’s stock 4412’s?
BONESTOCK GOATS
'99 Bonneville SE Sedan
Old 08-24-2023, 11:14 PM
How about some actual specs on this engine, Jeff should be able to share them with you.
Cam, compression, Holley carb part numbers, head air flow numbers, header size, fuel octane, etc.
Please post the dyno sheets if you would.
The Following 2 Users Say Thank You to b-man For This Useful Post:
Old 08-29-2023, 07:48 PM
KGTO's Avatar
KGTO KGTO is offline
Curious too.....
1967 GTO 416 5-spd streetcar 11's on HP low 10's 150 shot
1965 GTO 10-71 Littlefield high-helix retro/Bird (untuned) 8.44 @159 3500+lbs 10.5W's SOLD!
1964 421 GP-Sold
6.0 cert. Fiat bodied altered blown alcohol Pontiac IAII-Sold
Old 09-05-2023, 03:07 AM
Default KRE Tripower intake
I have sent an inquiry to Jeff Kauffman. Waiting for more information on engine specs.
The Following User Says Thank You to mike w For This Useful Post:
Old 12-04-2023, 02:17 PM
KGTO's Avatar
Has there been any more follow up to this? Maybe on another thread I missed. Mostly I'm still curious about the Holley carbs that were used
1964 421 GP-Sold
Old 12-05-2023, 08:15 AM
MidnightAuto's Avatar
MidnightAuto MidnightAuto is offline
Yes, love to hear more.
Theory on why Holley perform better?
What were the motor details? Cam, etc.
Would have liked to see new intake vs stock dual plane or repop aluminum….
Old 12-07-2023, 02:12 PM
I, too, would like to see the comparisons. Which Holley carbs? Stock Rochester Tri-Power carbs?
How do the numbers compare with Rochester carbs on the new intake vs. stock?
BONESTOCK GOATS
Old 12-07-2023, 03:14 PM
tom s tom s is offline
I think the Holleys are bigger.Tom
Old 12-07-2023, 05:21 PM
KGTO's Avatar
I just reached out to Jeff as this is something I'm seriously considering to do this winter.
1964 421 GP-Sold
Old 12-22-2023, 09:52 PM
Default Rochester carbs on KRE manifold
If anyone is interested,, I could supply the same carburetors that were tested by KRE on the new manifold.
The end carbs are correct Tripower carburetors. Center is an excellent clone. All three are opened up to 1 3/8 inches. Center carb has an electric choke added
Kaufmann still has the carburetors, but I can get them back when needed.
I am also building a pair of end carburetors that are also opened up oversize.
If anyone is interested, give me a call 309-360-6385 Mike Wasson, Illinois
Old 01-02-2024, 11:36 PM
Any insights on an a/b test isolating only the manifold? Same carbs, stock intake vs kre?
Old 02-10-2024, 11:14 AM
carcrazy carcrazy is offline
Strongly considering going down this road with the current build for my 62 Pontiac. I'll be in touch in about a month or so.
