SOLD Parts The parts in here have already been sold. The topics will be kept for a few months for reference. |
Here is the listing I have on FB:
This is a first gen 10-bolt GM rear end. Perch's are deep/for multi-leaf springs. 42 7/16" wide between perches. Fits 67-69 Camaro's and Firebirds. I think* some Nova's too. It's new rebuilt/never broken in or used, built by online or Jim and JD racing. Here is the spec: specs- -10 bolt 8.5 housing mutileaf perch set-up media blasted, cleaned in and out, primed and painted chassis black. - Spring perch center to center is 42 7/16" Stock firebird Nova Camaro -NEW EATON 30 SPLINE POSI UNIT. ****UPGRADE**** normal is 28 spline -NEW 3.73 YUKON BRAND STREET/STRIP PERFORMANCE GEAR SET. -NEW YUKON BRAND HEAVY DUTY 30 SPLINE STREET/STRIP ALLOY AXLES DUAL DRILLFOR 1/2 OR STOCK PRESS IN STUDS. ****UPGRADE**** normal is 28 spline -ALL NEW TIMKIN BEARINGS INCLUDING AXLE BEARING AND SEALS. -BACKLASH SET AT .007 FOR PERFORMCE APPLICATION -BACKING PLATES INCLUDED |
Bump 1500$
Nice rear - what is width drum to drum?
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears ‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded) '69 LeMans Vert, 350, #47 heads: Non-running project |
Looks like a nice unit.
Don`t see many Pontiac guys from Anderson SC. We`ll be moving to that area in a few years. GLWS.
`70 Firebird,Original Owner car Ken French Built Chassis Carlquist Competition Engines IA2 505 Competition CNC Ported Super Chiefs CCE Ported Gustram Twin Dominators from Shaker 455 963 HP `09 Electra Glide Standard. `03 F-350 7.3 6-speed 4x4 Crew Cab Dually. |
Looks like outer width is right at 60" and inner width (inside of backing plate) is 53.5.
Yeah - its a good rear end. Never used since being built and is about as strong as a coveted 12-bolt first gen Camaro/FB rear end. |
Forgot to update this:
1500$. Local pickup. Ready for install - forged axles/posi/new brakes/drums, etc. Never installed or broken in. Built by a pro! |
This is sold.
