Old 08-28-2023, 08:04 PM
arbys's Avatar
arbys arbys is offline
Default Looking for measurements for 66 driverws outside rear view mirror
I've checked the archives and didn't find anything because the photos were not supported. Does anyone have the measurements so that I can install mine.
Old 08-28-2023, 09:44 PM
242177P's Avatar
242177P 242177P is offline
I would have been happy to measure it for you,
but you couldn't even be bothered to respond
the last time I answered your questions. When
Bart admonished you for just how inconsiderate
you are, I chalked it up to 'maybe he had a bad
day'. Nope, he was right.
You're only here to leech off of us. Call GM. Ask
for Customer Support.
The Following User Says Thank You to 242177P For This Useful Post:
Old 08-28-2023, 10:19 PM
arbys's Avatar
Sorry that you feel that way. Maybe you don't know what is going on in other people's lives.
Old 08-29-2023, 12:04 AM
242177P's Avatar
So you think you're the only person that has
troubles? Other members have gone through
tough times, none of them pulled an Arby. If
you honestly find that you're so overwhelmed
that you can't even respond after soliciting info,
maybe you ought not to be wrenching.
PS- Couldn't help but notice you made time
for me *now*. Weird.
Old 09-04-2023, 09:58 AM
ftwmlp's Avatar
ftwmlp ftwmlp is offline
I could have sworn I had a template someone in this forum provided, but I'll be d__mned if I can find it. I know this attached pic is not the detail you need, but if may give you a starting point.
Name:	door mirror placement.jpg
Fort Worth/Dallas TX area
1966 GTO Fontaine Blue
389 CID Carter AFB
Muncie 4 speed (orginally an automatic car)
Old 09-04-2023, 10:59 AM
arbys's Avatar
Thanks for the response. I just drilled the holes this morning from some on another forum that supplied the dimensions. the front hole was easy drilling since it was the original factory hole covered with an all over skim coat and paint. What are the chances?
Old 09-04-2023, 02:02 PM
Cammer-6 Cammer-6 is offline
best anyway
bondo over a hole is just asking for trouble
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 09-04-2023, 09:32 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
Ditto on that, as l’ve notice before.
If I offer sound advice to anyone on the 65-66-67 GTO’s, all I expect is a two second Thank You, since they did find the time to get on this site.
The Following User Says Thank You to 60sstuff For This Useful Post:
