Old 09-28-2023, 05:09 PM
Shiny Shiny is online now
Default Movers Hurt my Valance - Fix or Shop?
Recent move did not go well for my valance. It was pretty straight and no rust-through.
I will file a claim but realistically, I'm not sure I could find a replacement easily... it's a one-year 70 Tempest/LeMans part so likely available used only. There is a NOS part on EBay right now at $2K but I think not...
How hard does this look to straighten? I have low skills/experience but not afraid to try if it avoids a bigger hassle finding and shipping one in better shape.
Mike
ID:	620692   Click image for larger version
Old 09-29-2023, 11:47 AM
pfilean's Avatar
pfilean pfilean is offline
That doesn't look all that bad. If you don't want to try it yourself it looks like a part you could take to a body shop and let them do it.
Or first try FranksPontiacParts in CA or Desert Valley around Phoenix.
Old 09-29-2023, 04:49 PM
400 4spd.'s Avatar
Ain't skeered.
It's fixable, but it would be wise to have the car with fenders mounted to verify the contours against them.
The Following 2 Users Say Thank You to 400 4spd. For This Useful Post:
Old 09-29-2023, 07:57 PM
Originally Posted by 400 4spd.
Aint skeered.
You must know me!
Or at least my car....
Thank you... good advice.
I'll have to wait for the claims adjuster before I do anything but I can definitely campaign to get it repaired.
I've had good luck with both Frank's and DVA recently, so can check with them too. I just expect shipping would cost more than the part but if they had one, it could establish value.
Mike
ID:	620759   Click image for larger version
Old 09-29-2023, 08:42 PM
gtospieg gtospieg is offline
It seems to me that any expense for repair or shipping should be the responsibility of the shipper who did the damage....
The Following User Says Thank You to gtospieg For This Useful Post:
Old 02-29-2024, 07:13 PM
After the movers literally ignored our claim, calls, and emails for 3 or 4 months I was finally able to get it settled by opening a complaint with the Better Business Bureau.
So I can finally move forward on the valance. I'll try to straighten it out but if my limited skills prove inadequate for the task, I got a few dollars out of the movers to go shopping for a replacement.
Mike
Old 02-29-2024, 07:27 PM
Cammer-6 Cammer-6 is offline
Doing one thing the wrong way may squish the chances of having it repaired correctly.
Let a pro do it.
It needs to be bolted down and pulled the same way it was dented.
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 02-29-2024, 07:33 PM
Let a pro do it.
Old 03-08-2024, 11:52 AM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is offline
I've fixed much worse. Some time with a body hammer and dolly will go a long way. I just finished one from a 70 Lemans and had to remove the brackets for the turn signals to get behind it.
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
Old 03-08-2024, 12:17 PM
Thanks for the encouragement Jack
I will definitely work on it myself and I'm optimistic about my odds. It's next on my project list, as I need the turn signals to get the car drivable.
Mike
