Old 10-01-2023, 11:42 AM
lucky1 lucky1 is offline
Default Packing a new mech fuel pump with wheel bearing grease ?
When installing a new mech fuel pump is it a good practice to pack the cavity where the pump arm protrudes with wheel bearing grease ?
What benefit? Any harm ?
Tks.
Old 10-01-2023, 11:51 AM
i82much's Avatar
i82much i82much is offline
if anything i would put assembly lube on the pump arm.
The Following User Says Thank You to i82much For This Useful Post:
Old 10-01-2023, 11:52 AM
i82much's Avatar
wheel bearing grease is solid at room temps ... seems like it would clog up something important.
Old 10-01-2023, 11:57 AM
PunchT37's Avatar
PunchT37 PunchT37 is offline
I would not pack that thing. Put some motor oil on the cross pin, put a layer of grease on the flat of the arm that contacts the eccentric, and bolt it up.
The Following User Says Thank You to PunchT37 For This Useful Post:
Old 10-01-2023, 12:36 PM
Tom Vaught's Avatar
Boost Engineer
Bad idea to pack the fuel pump as proposed.
Tom V.
The Following User Says Thank You to Tom Vaught For This Useful Post:
Old 10-01-2023, 01:54 PM
Mr Twister's Avatar
Mr Twister Mr Twister is offline
You are thinking oil pump, not fuel pump. Some older engines benefit from the oil pump being packed with grease so it will prime. This is generally helpful when the pump has a long pickup, or the gears are not submerged in the engine oil in the pan. Some Pontiac builders do pack the pump, I don't personally think its a necessary procedure
Old 10-01-2023, 02:54 PM
Dragncar Dragncar is offline
Oil pumps, pour some Lucas into her. Instantly primes every time.
But it sounds like the OP is indeed talking about a fuel pump with "protruding arm".
And there is a "cavity" on that arm. But it is on the wrong side so grease there would do nothing but end up in your oil.
Old 10-01-2023, 03:31 PM
geeteeohguy's Avatar
Tks.
Benefit? Zero. Harm? Possible damage to the pump and eccentric due to grease not being compressible. For sure damage to the diaphragm from the petroleum base in the grease rotting the rubber in short order.
Jeff
The Following User Says Thank You to geeteeohguy For This Useful Post:
Old 10-01-2023, 07:37 PM
Its a crazy idea, don't do it.
But that diaphragm is made to hold up to gasoline so grease is not going to break it down.
Old 10-01-2023, 08:34 PM
PunchT37's Avatar
I`m thinking of the grease holding back lube to the arm pin, and not allowing the diaphragm housing to "cool". The upper housing clogged by grease to not allow to breathe back into the timing cover.
Old 10-01-2023, 11:10 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
I do know some Chevy guys use grease on the pushrod so it stays up enough the slide the arm in.
Skip Fix
