Old 10-01-2023, 07:59 PM
Rob in NH's Avatar
Rob in NH Rob in NH is offline
Default Speedometer issue
My speedometer bounces after 40 mph, is this a cable issue or the speedometer is worn out ?
Old 10-01-2023, 09:51 PM
JLMounce JLMounce is offline
Could be either or both. In my opinion, the cable is the easier job on a '69 (assuming, based on your avatar). I'd start there. If that doesn't cure the issue, the speedometer itself needs servicing. That becomes a good time to freshen up the dash carrier, do a dash harness if needed, replace bulbs etc.
-Jason
1969 Pontiac Firebird
Old 10-02-2023, 08:26 AM
Cammer-6 Cammer-6 is offline
some models have a 2 piece speedo cable assembly
its almost like they didnt have the right ones in the parts bin.
but Im sure engineering dept will say different.
You can disconnect and add some speedo cable lube and try that first.
Also check for sharp bends or contact with exhaust.
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 10-02-2023, 07:38 PM
Rob in NH's Avatar
Thanks for the replies, I will try oiling it up to see if that helps.
Old 10-02-2023, 08:56 PM
rdl's Avatar
rdl rdl is offline
Have you tampered with any components that might be a clue to explain why this has started to happen?
'69 R/A III Firebird Convertible
14.0s @ 100.8mph AMA/OEM/OER
Old 10-02-2023, 09:18 PM
Rob in NH's Avatar
I haven't messed with the cable
Old 10-02-2023, 10:10 PM
rdl's Avatar
rdl rdl is offline
Post
Check the connection at the gage first to be sure it’s properly clipped in. Then check the condition of the plastic gear in the transmission end (looking for worn or chewed teeth). Also, you can place a drill on that end (gear removed) and test the gage that way.
Old 10-04-2023, 07:46 AM
necdb3's Avatar
necdb3 necdb3 is offline
If you pull the cable out of the jacket, I usually wire wheel the cable then oil it. Sometimes you'll see a clump of plastic from the jacket on the cable which will cause the bounce.
