Does anyone have a picture of the rear wheel well of a 61 Catalina,specifically the inside view of the forward lower corner of wheel well. Mine is rusted away.
Thanks Tony 917-681-6534 |
This is the inside lower driver's side corner of a '61 Bonneville coupe I once owned. Catalina would be the same.
The Following User Says Thank You to 61-63 For This Useful Post: | ||
Here are three pictures. These are not original but when I replaced the rockers I tried to make it look like it once was. This can be a bad area because if the rear window has leaks the drainage channel under the window channels the water to this area to drain out of the rockers.
Sorry I can't get better pictures but I'm 4 weeks past knee replacement and I just can't get low enough to jack the car up and get on a creeper. |
The Following User Says Thank You to pfilean For This Useful Post: | ||
Thank you very much
