Old 10-02-2023, 04:07 PM
PDC PDC is offline
Default Grounded vs. Non-Grounded LED Flasher Relay
In swapping over to LED exterior lights, I ran across certain LED flashers that have the ground wire that needs to be grounded in order to function and others that do not have a ground wire. I am wondering what the difference is - why some LED Flashers need to be grounded while others do not?
Grounded:
https://upauto.com/led-flasher-12v-2-terminal-90650
No Ground:
https://www.ceclighting.com/products...rtNum=EF32SS-R
Thank You!
Old 10-02-2023, 04:15 PM
Mine was like the second one - ground is better than no ground
I couldn't get the old flasher out of the fuse box - maybe it's rusted in there
I was able to change the signal flasher and so far so good...
Old 10-02-2023, 07:43 PM
Bill Hanlon's Avatar
A flasher with a separate ground connection should flash at the same rate no matter what the electrical load as long as the load is within the operational limits of the flasher.
The Following User Says Thank You to Bill Hanlon For This Useful Post:
