Old 10-05-2023, 07:13 AM
steve25 steve25 is offline
Default Pontiac cast iron production.
In the great and very informative Pontiac made film that can be found on You tube titled “455 casting and machining for original production in 1970” it’s stated that Pontiac made its cast iron at that point in time by the electro arc method as opposed to the Crucible method.
The electro arc method produces a better quality cast iron .
My question going out here is does anyone know when Pontiac changed over to this to this better production method?
It’s also stated in this film that when the factory applies the the final balance job to each motor that the result is a motor balanced to within 1 1/2 inch Oz.
Pretty darn good you have to admit!
If you watch this 11 minute long video note that at one point the audio drops out for some two minutes, so it’s not on your end.
On a side note here I just finished porting a set of AMC 390 heads and in all my decades of grinding on cast iron I have flat out never encountered a head that ground so easy, surprisingly soft cast iron !
Old 10-05-2023, 08:27 AM
PAUL K's Avatar
PAUL K PAUL K is offline
Didn't watch the video but those AMC heads move some air. Those were the first heads I worked on that had the coat hanger stuck in the water jacket. The Wenzlers were the second. I didn't figure out what their purpose was until Frank from AP explained it because they caused an issue with a batch of their blocks during the casting process.
Go fast, see Elvis!
Old 10-05-2023, 08:52 AM
Yup found out about the so called coat hanger sand core holder on a straight 6 head so darn long ago that I don’t even recall what the heck brand it was from!
Flow wise, yes the AMC head has a as cast intake throat size that’s a very large percentage for its valve size used.
In the high lift range they flow right in the ball park of what the post 1970 455 HO heads do ( at least on the intake side) ,but with a fair amount smaller port volume.
In fact to me a volume just right for a every day street 390 motor.
Old 10-05-2023, 09:02 AM
Interesting video. Was that the Super Duty valve cover sticker on that engine visible in the last few seconds? Here's the link-
https://youtu.be/9LuXf6gJ-jg?si=WEgzZyLLg1_ETqRa
The Following 2 Users Say Thank You to Greg Reid For This Useful Post:
Old 10-05-2023, 11:03 AM
johnta1 johnta1 is online now
It's interesting that the video is still up. It used to be when it (and the others in the series) were on, it seemed to be taken down. Not sure if it was Pontiac at that time or GM.
I have most of the videos downloaded. (when it was easier to download)
It's a very cool video, need to see the others in the series.
The Following 2 Users Say Thank You to johnta1 For This Useful Post:
Old 10-05-2023, 11:35 AM
Stuart's Avatar
Stuart Stuart is offline
POCI also has it posted on their channel: https://www.youtube.com/watch?v=gMVEXmjxxWs
The Following 3 Users Say Thank You to Stuart For This Useful Post:
Old 10-05-2023, 11:43 AM
Yes, I thought I saw that same thing on the valve cover, but this is 1970 .
But then again what do know now is that the SD455 was in the works before the round port 455 HO motors, so maybe that was one of the preproduction test motors for the engineering dept.
Ram Air IV Jack's Avatar
Ram Air IV Jack Ram Air IV Jack is offline
Lots of information out there but it is difficult to determine if it was true or not. I've heard over the years that the Pontiac RAIV blocks had a higher nickel content which made them stronger than other blocks. That has never been confirmed through reliable sources, but it is still talked about. Great to read and watch this stuff but be careful on what you believe!! As far as the AMC 390 engine, very good and I owned one in a Javelin years ago. It scooted along fine but the R&D at AMC couldn't match GM and the others, but I loved the AMX!
Old 10-05-2023, 11:56 AM
After watching another one popped up focusing on Fisher Body. I haven't finished watching but also very interesting.
Old 10-05-2023, 12:07 PM
Shiny Shiny is offline
Thanks for the link.
I don't have any idea when they would have changed their cast iron process but I enjoyed watching the video. Very cool to see the scale of that operation.
Even though my education was in metallurgy, I'm kind of glad I didn't work in primary metals beyond a couple summer jobs. That's a rough world.
It's sad that so much manufacturing is gone, though.
On the other hand, I cringed watching the workers man-handle crucibles of molten iron and breathing all the crap. This is a great example of hazards that probably led to OSHA regulations. I'm sure those jobs paid well, but IMO nobody got paid enough to take that risk... but the world back then was different.
The Following 2 Users Say Thank You to Shiny For This Useful Post:
Old 10-05-2023, 01:02 PM
How do you figure that 1.5 ounces is “pretty close” when we shot for three grams difference in piston balance in aircraft recip engines? 1.5 ounces is 42.5 grams….
Dr. Thomas Sowell
Old 10-05-2023, 01:50 PM
Keith Seymore's Avatar
Just an observation, but "inch ounces" is a torque measurement; "grams" is a straight mass measurement.
K
'63 LeMans Convertible
'63 Grand Prix
'74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/
The Following User Says Thank You to Keith Seymore For This Useful Post:
Old 10-05-2023, 04:22 PM
Burgess's Avatar
Burgess Burgess is offline
I just watched this one about Fisher Body, also very interesting. There are several sections featuring the Firebird and G/P design.
https://www.youtube.com/watch?v=yYgxgGlN8CM
Old 10-05-2023, 07:46 PM
K
Keith, they say 1.5 ounces. That is still 42.5 grams. I don’t know about you, but 42.5 grams out of balance is a non starter for me. I went back an re-read the OP’s post. Yes, 1.5 inch ounces would be a very low breakaway point in an engine.
Dr. Thomas Sowell
Old 10-06-2023, 05:52 AM
I will go back and watch it again and listen more closely, maybe it was stated as 1/2 a inch Oz.
Jack to help answer your block strength question here is a copy of the 1970 production specs.
Note that the block material on all the engines is listed as being the same.
When you look at my other page shot next to the Crank listing you will see that only the 4 bolt main caps are speced as being the better more ductile Armasteel cast iron.
If the RA4 blocks where made of better cast iron I would expect that they would have a notation as being made by this better formulation of iron.
ID:	621128   Click image for larger version
Old 10-06-2023, 11:42 AM
1.5 inch ounce equates to .01 ft/lb. I priced an inch ounce torque wrench last night; nearly $400.
Dr. Thomas Sowell
Old 10-06-2023, 03:31 PM
Schurkey Schurkey is offline
I have not watched that video for a few months.
The way I remember it, they say the balance is within 1 1/2 ounces, but NOT "inch-ounces". They don't specify if that's 1.5 ounces at the front of the crank, and 1.5 ounces at the rear, or 1.5 ounces total, or something else.
What they say...is almost totally meaningless in terms of balance (except that by aftermarket standards, there's no way to interpret it that their 1.5 ounces of imbalance doesn't SUCK. The only saving grace is that most of those engines never saw 5000 rpm. Maybe never saw 3500 rpm.)
"Nickle" in the iron of engine blocks and cylinder heads seems to be a myth that won't die. There's a hundred formulations of cast iron, plus heat-treatment including "lack" of heat--cryogenics. When Chevy wanted a higher-quality block, they added--and advertised--TIN, not nickle.
Pretty-much every one of the GM "sister divisions" has enthusiasts that brag-up the quality of the iron in their blocks and they always claim that their brand uses "nickle" in the iron...except Chevy with their mostly-soft iron, heavy bore wear and seat recession. Same with Ford "Fairlane" "90 Degree" "Small-blocks". Garbage iron.
The Following User Says Thank You to Schurkey For This Useful Post:
Old 10-06-2023, 03:55 PM
That’s what I was thinking! 1.5 ounces is 43.5 grams. I don’t care what engine you’re talking about; that is huge amount to be out of balance.
Dr. Thomas Sowell
Old 10-06-2023, 04:04 PM
When you read up on the arc melting process just like what’s stated in the video it produces a cleaner iron with less impurities then the old crucible method at the get go.
So does this not make for a better cast iron?
My main reason for this post was to see if for instance the change over to the electro arc method may have came about at the same time in 55 with the first V8s showing up, or if it was later.
Old 10-06-2023, 04:36 PM
Dragncar Dragncar is offline
When Mike Lewis balanced my rotating assembly he told me not to mix up my pins with the pistons.
Whatever the tiny amount of difference it was it was calculated in the balance job.
Its good to have a detail nut as your machinist.
The Following User Says Thank You to Dragncar For This Useful Post:
