Old 10-16-2023, 03:29 PM
KJ223 KJ223 is offline
Default Increase compression, Pontiac 350 6X-4 heads
Hi everyone, I’ve been reading several different forums about increasing compression ratio, but they are mostly all about Pontiac 400s. I have a 75 Pontiac 350 and as far as i know it’s the original engine and never rebuilt. It runs great and I put a summit 2800 in it a couple months ago. I’ve been looking into how to get more power out of this set up and I’ve heard about increasing compression. From what I understand my motor has around 7.5:1 compression ratio. What can I do with these 6X-4 heads to increase power? Do they need milled, and if so how much can be taken off? I also want to put headers on, right now I have a pypes dual exhaust and stock manifolds since I can’t remove the manifold bolts without them snapping off in the head, so if I have to pull the head for milling and headers I might as well do them at the same time. I also don’t want to have to pull the engine out of the car and change anything else as I don’t have an engine stand or crane, and I also don’t want to rebuild the motor if it’s not necessary. Thanks
Old 10-16-2023, 04:02 PM
JLMounce JLMounce is offline
I don't think I would spend much time or money trying to get the 6x-4's to get you where you want to be. I'd look for a set of #48 heads which would have been found on a 69 350HO. They are a small chamber head with the 1.94 intake valve. On a stock displacement 350, it my opinion that you don't really need the 2.11 valve. It's shrouded by the small bore anyhow.
Put a good spring for your 2800 on the head and add a quality set of 1.5 rockers and pushrods. You should end up with around 9:1 compression ratio with these heads and with a bit of bowl work and a quality header, you should see a decent bit of performance gain over what you currently have.
I know you don't want to pull the engine, but one thing to keep in mind is that you've probably got a 40psi oil pump in that engine. If you're after more performance and are going to be driving the car to take advantage of it, upgrading that oil pump should be high on your priority list before you're forced to rebuild the engine. Food for thought.
-Jason
1969 Pontiac Firebird
The Following User Says Thank You to JLMounce For This Useful Post:
Old 10-16-2023, 04:09 PM
Plenty of compression increasing/head swapping advice in your previous thread:
https://forums.maxperformanceinc.com...d.php?t=868214
Old 10-16-2023, 04:30 PM
Stan Weiss's Avatar
What ICL did you degree the Summit 2800 in at? Have you done a cranking compression test? If so what numbers are you seeing?
Stan
Pontiac Pump Gas List
Old 10-16-2023, 04:39 PM
Stan
I’m not sure what ICL stands for, I used a new stock style timing set, so I didn’t degree the cam other than what stock was. I’ll have to do a compression test to see what it says.
Old 10-16-2023, 04:42 PM
I’ll read through my previous thread again, but I do have the 60psi pump, I know this because when the engines cold the psi will hit 60-62 according to the stock gauge, and not climb any higher. Unless that’s not how you determine what psi your oil pump is, I don’t know how else I would check that
Old 10-16-2023, 05:01 PM
steve25 steve25 is offline
Was your motor originally a 2 bbl 350?
1967 and up small valve heads are 1.96” intake valves, not 1.94”
Old 10-16-2023, 05:18 PM
grivera's Avatar
grivera grivera is offline
When the engine is hot, what psi are you seeing at ~3000 rpm? Assuming the engine isn't worn out, should be close to 60
Will Rivera
‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded)
Old 10-16-2023, 05:23 PM
When hot it’s right below 60 probably in the 50-60 range, hot idle psi is ~25. I use valvoline vr1 10w-30
The Following User Says Thank You to KJ223 For This Useful Post:
Old 10-16-2023, 05:44 PM
Thank you for the clarification
definitely sounds like a 60psi pump. Also does sound like the engine is in decent shape.
-Jason
bdk1976 bdk1976 is offline
Why do you want to put headers on a fairly stock P350? Are you a masochist?
Old 10-16-2023, 06:01 PM
Maybe he’s looking for the extra 15 HP he will have at full throttle and the extra fuel mileage and no cost power at times when his foot is not on the floor.
Old 10-16-2023, 06:25 PM
gtospieg gtospieg is offline
I've never heard of a set of 48's having 1.94 or 1.96 valves(unless custom). I was under the impression they all have 2.11/1.77 stock.
Old 10-16-2023, 06:28 PM
Yes, all of them where born with 2.11” intake valves.
Old 10-16-2023, 06:49 PM
Thanks Steve I was 99.9% sure that was the case....
Old 10-16-2023, 07:28 PM
grivera's Avatar
Thanks for the info!
Will Rivera
Old 10-17-2023, 10:18 AM
78w72 78w72 is offline
You can definately increase the comp some by milling the heads, 6x-4 heads will have about 6cc reduction with a .030 milling, ive went close to .060 on 6x4 heads before with no problems bolting to an intake, but you can also take the same amount off the intake surface if thats a problem, most I had to do was elongate the bolt holes on the intake a little if they didnt start easily. This chart shows how much milling is needed to reduce CC's. http://www.wallaceracing.com/headmill.htm
You can add headers to a mild built street engine for a little extra power & exhaust sound... they are usually easy to install if you follow the instructions most headers come with, jack the car up as high as possible & install from underneath with a helper up top to guide them in. The key to leak free headers is using bolts that will lock, lock washers or header bolts with serrations under the heads to help keep them tight... & most of all re-torque after a few heat cycles & check again once or twice a season. I have headers in use for 15+ years using the supplied paper gaskets that came with the hedman headers that are still leak free.
Old 10-24-2023, 02:36 PM
What would having them milled .030 do? I looked at the chart and I see it’ll reduce the combustion chamber but what does that do to the compression ratio, like how much does it increase by? I’m still trying to learn all this. I’m at 7.6:1 right now based on other posts and previous replies, what would it change to 8:1, 9:1?
Old 10-24-2023, 02:44 PM
Milling .030 might get you up to 8:1 at most.
For any real increase in compression ratio a head swap is in order, no way around that.
Old 10-24-2023, 02:49 PM
With 6X castings for every CC you want to reduce the chamber size by to increase compression you will need to mill .006” off of the deck surface of the head.
For every 5 CCs you mill off the head you will gain a 1/4 point in compression.
