Old 10-18-2023, 06:56 PM
Gator67's Avatar
Gator67 Gator67 is offline
Default lightly textured paint recommendations
I'm helping a friend with a low budget driver type car (80 Firebird). It's a decent car that could be restored some day, but for now, he's looking for budget minded solutions to get it on the road and looking decent. Anyways, he's looking for a low sheen black paint to use in a trunk that's lightly textured. Something like 3m rubberized undercoating that comes in a spray can, but harder and won't rub off. He considered truck bed liners like U-pol Raptor liner, but they all seem to be too textured for his taste. spray bomb or 2k in can. Any recommendations?
Old 10-18-2023, 07:47 PM
bdk1976 bdk1976 is offline
2k bedliner with a compressor and gun and crank up the pressure. It should atomize better and lay flatter.
Old 10-18-2023, 09:24 PM
Trevor78 Trevor78 is offline
Whatever he sprays is permanent in there, unless trying to fill every pinhole at same time.
Old 10-19-2023, 05:01 PM
Tempest's Avatar
Tempest Tempest is offline
I have found that you can control the texture by the distance the can is from the surface. Close is a lot on texture, far away is less. (but more coats)
Old 10-19-2023, 05:42 PM
Tim john Tim john is offline
Hi Jeff, Hope all is well with you and your family.
Kennedy tool boxes have a textured finish and they do sell their paint in spray cans. They offer their traditional chocolate brown and red but one could easily follow up with a top coat of a SEM semi gloss or satin black, also available in a spray can. Definitely not as permanent as the bed coat linings so future removal would be a breeze.
Tim john---
Tim john---
Old 10-20-2023, 08:41 AM
Cammer-6 Cammer-6 is offline
Hammered paint has a texture
you can buy in the box stores
I cant imagine reversing the mess of using bedliner
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 10-20-2023, 08:42 AM
duplicate
Old 10-20-2023, 11:36 AM
gtohunter's Avatar
gtohunter gtohunter is offline
I used truck bed liner on wheel wells, interior floor, trunk floor (before splatter finish) on my 68 after thinning it with acetone, about 1 to 1....went on and flowed out without the pebble finish, but is still plenty tough.
Jimmy M
68 GTO
The Following User Says Thank You to gtohunter For This Useful Post:
Old 10-20-2023, 11:53 AM
Tempest's Avatar
Sounds like a good idea gtohunter
What kind of spray gun did you use? (tip size?)
