Old 10-19-2023, 12:46 PM
Skippy597's Avatar
Skippy597 Skippy597 is offline
Default What exhaust hangers
I'm installing a flowmaster 1041 exhaust kit on my 66 lemans and need the mounting hardware. Was wondering what you guys are using for hangers. Thanks in advance
Old 10-20-2023, 08:18 AM
NatW_RI NatW_RI is offline
I can't help - but please provide feedback (and if possible pics) as I'm interested in this system for my 66 gto as well. Thanks!
Old 10-20-2023, 11:45 AM
Skippy597's Avatar
Will do. I'll take pictures and make a post when I install it. Still haven't decided on mufflers though.
Old 10-21-2023, 09:22 PM
chuckies76ta's Avatar
These stainless hangers are great. I paid like $5 each though. You can heat the stainless rod and bend to suit your configuration. Then weld them to what ever your holding. Bolt other side to vehicle body.
https://www.amazon.ca/Walker-36516-U...514859022&th=1
Old 10-21-2023, 11:28 PM
How about the factory hangers sold by most restoration parts houses?
That’s what I have on my ‘64 Le Mans. Not a big deal to bolt up a fabricated bracket to the hangers if things aren’t quite lining up.
The last few Flowmaster A-body 2-1/2” mandrel bent dual exhaust kits I’ve used all came with the factory muffler hangers, all the pipe clamps and factory type tailpipe hangers as well.
Old 10-23-2023, 03:48 PM
Formulajones's Avatar
Like B-man mentioned, I prefer to use factory hangers that are reproduced from about any restoration supply chain you choose.
I use them even if the kits come with their own hangers. Primarily because the factory hangers offer much more cushion and vibration resistance by design, and they fit like the hangers are supposed to fit. I find they also tend to help with drone issues as they isolate/insulate much better.
https://youtu.be/XqEydRRRwqE
Old 10-23-2023, 08:43 PM
Skippy597's Avatar
Would anyone be willing to take pictures of their hangers and the locations. Im working off of nothing here on the car. Thanks
Chuckie those are the type I was looking at and have used previously on other cars. Theyre simple and work. Thanks
Old 10-23-2023, 10:21 PM
Pictures of some factory hangers with add-on brackets to use 3” pipes.
ID:	622137   Click image for larger version
ID:	622138   Click image for larger version
ID:	622139   Click image for larger version
ID:	622140   Click image for larger version
Old 10-23-2023, 11:21 PM
Skippy597's Avatar
Thank you so much! That helps a lot!
Old 10-24-2023, 09:37 PM
Entropy11's Avatar
Entropy11 Entropy11 is offline
I used the Pypes restoration type hanger kit on my ‘68 (2.5” HGH30). Same kit for 64-72. I am very happy with it and it mounted in the factory holes perfectly. Maybe overkill being stainless but it’s a nice fitting quality kit.
