Power window doesn’t work
69 Gto drivers door window if you hit the switch up or down you can hear a click at the motor but that’s it no grunt of the motor zero motion. Is it time to replace or hit it with BFH. What am I missing? Thanks
Use a test light and check for power AND ground. If all is ok try lubing the motor. I had to clean and lube the window motors on my dd's car because he wouldn't use them. He didn't want to "wear them out".
