Old 10-29-2023, 06:25 PM
joes455 joes455 is offline
Default Helicoil
Are the edelbrock heads accessories holes helicoiled ?
76 T/A 455, cnc chamber E heads,OF hyd roller ,yella terra shaft rockers 11.47 119
Old 10-29-2023, 07:00 PM
64speed's Avatar
64speed 64speed is offline
Mine arent
Old 10-29-2023, 07:52 PM
Good I just stripped out the big bolt hole for the alternator ,(bolt was too long)Helicoil will be replacing it.
The Following User Says Thank You to joes455 For This Useful Post:
Old 10-29-2023, 08:12 PM
64speed's Avatar
Did the same thing
Old 10-29-2023, 09:58 PM
I can’t figure out why none of the aluminum head manufacturers won’t put Helicoils or TimeSerts in locations where steel bolts are going to be threaded in and torque applied. The combination of steel bolts and aluminum threads triggers galvanic corrosion.
Dr. Thomas Sowell
Old 10-30-2023, 01:23 AM
lust4speed's Avatar
Edelbrock exhaust bolt holes are helicoiled, but they are the only holes to receive the coils.
Mick Batson
The Following User Says Thank You to lust4speed For This Useful Post:
Old 10-30-2023, 01:50 AM
glhs#116's Avatar
glhs#116 glhs#116 is offline
If you check my long-running thread you will see that I recently discovered that on my 87cc round port heads the rocker stud threads are also coiled.
Sam
Sam Agnew
Where you come from is gone; where you thought you were going to, weren't never there; and where you are ain't no good unless you can get away from it.
Ministry - Jesus Built My Hotrod
Old 10-30-2023, 02:35 AM
wakesupremo wakesupremo is offline
Sorry to hijack the thread. This weekend whilst at the race track, I was re jetting my carb and stripped a thread for the float bowl to carb body. Its a holley 800 double pumper. Presumably I can helicoil this? What thread size is it?
Old 10-30-2023, 03:38 AM
Nobuddy Nobuddy is offline
#12-24 which is a standard UNC thread.
Old 10-30-2023, 09:29 AM
mgarblik mgarblik is offline
It's all about time and money. When I get my hands on a Pontiac aluminum head, the first thing I do is install coils in every single threaded hole in the heads. If I don't, I get bit every single time. 2 recent examples. KRE hi ports for Eric's road racer. Installed coils in every hole except the spark plugs. Removing the plugs after hand installing them after painting the heads, 2 of the plugs came out with the threads! The holes were left very jagged after CNC porting and I missed it. Had to time cert the new heads. My personal CNC Edelbrock D-ports. I Heli-coiled every threaded hole in the heads except the intake manifold. Of course the left rear hole ended up stripping out where the throttle bracket attaches for the cross shaft. Had to heli-coil it with the head installed in the car. Very difficult. It takes me a full working day to install all the coils in a manual mill, locating every hole center. So it is a bunch of work. But worth it, IMO. I do not put inserts in spark plug holes, but I learned my lesson and check and massage the threads on every head, especially if it was CNC ported. Live and learn.
ID:	622500   Click image for larger version
ID:	622501   Click image for larger version
ID:	622502   Click image for larger version
Old 10-30-2023, 10:52 AM
Formulas Formulas is offline
Its very important to pay attention to thread engagement into aluminum as well
i usually bottom tap blind holes and use a bolt that catches maximum threads, sometimes start out with a long bolt and trim it down using a thinner washer under the bolt head trim the bolt until it clamps then put thicker washer under the bolt head
Old 10-30-2023, 02:28 PM
That's an excellent point. This is exactly what happened in my post above with the throttle bracket. I was installing the new bathtub intake and did not take into account the slightly different stack height of that intake and the bracket, bolt, washer. Only had 4 threads of engagement and they pulled right out. Just a dumb mistake. Heli-coils are much more forgiving in aluminum and have greater strength.
Old 10-30-2023, 03:14 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
Aluminum threads are why I've always worried about using a carb plate on an intake to lift a motor!
Skip Fix
Old 10-31-2023, 06:30 PM
Got the 3/8 kit from auto zone ,had to buy the 25/64 bit from lowes fixed in under an hour double checked depth of hole.Tightening it down felt much more secure.I was going the time cert if it was a helicoil that got pulled out.Glad I didn't have to I've heard the time certs are much more weaker
