Old 11-04-2023, 11:35 AM
importsmasher's Avatar
importsmasher importsmasher is offline
Default 65 Tempest AFB Choke Issues
So my 16 year old son has a 65 Tempest Custom 4 door. It came with the 326 2 barrel, but we had a 4 barrel intake and several AFB carbs kicking around, so we put a kit in one and swapped it. I'll be the first to acknowledge my lack of carburetor skills, but the car runs fine with it. The only issue we're having is with the choke. I set the choke to be closed when the engine is cold, and it will fire right up. But as it warms up, the choke opens less than halfway. If I adjust it so it's open when hot, it won't start cold. I tried another choke thermostat (admittedly, they're both used), but got the same results.
Any advice on how to make the choke work correctly? The choke and all linkage move freely. Any advice is appreciated.
Thanks,
Importsmasher
ID:	622786   Click image for larger version
Scott Baggiore
66 GTO convertible 389/4 speed (parents bought new)
73 Firebird Formula 400/4 speed
74 GTO 455/4 speed
74 Grand Am
Old 11-04-2023, 02:54 PM
Kenth's Avatar
Kenth Kenth is offline
Intake crossover open?
Vacuum in the fresh air line feeding air to the hot air choke system?
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 11-04-2023, 03:14 PM
Yes, the crossover is open, and I made sure the heat tubes were clear before we installed the intake.
Scott Baggiore
74 GTO 455/4 speed
74 Grand Am
Old 11-05-2023, 09:37 AM
Kenth's Avatar
Ok, looks like you need to adjust the choke rod:
Name:	AFB adj. choke rod.jpg
ID:	622811   Click image for larger version
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 11-05-2023, 09:41 AM
Thanks! I'll give that a try!
Importsmasher
Scott Baggiore
74 GTO 455/4 speed
74 Grand Am
Old 11-06-2023, 12:23 AM
Looks like the wrong choke rod. All the AFB's I have have a bend in the rod. You change the bend to lengthen or shorten the rod.
The Following 2 Users Say Thank You to Goatracer1 For This Useful Post:
Old 11-06-2023, 10:53 AM
61-63 61-63 is offline
This is an NOS AFB notice the bend in the choke rod.
Name:	nos AFB 2.JPG
The Following 2 Users Say Thank You to 61-63 For This Useful Post:
