Old 11-06-2023, 05:24 PM
54nomore's Avatar
54nomore 54nomore is offline
Default Carb Info Requested
Hi all,
I'm working on a '68 Quadrajet, Carter #4887S (Rochester 7028262).
Trying to find out what secondary metering rods and hanger were in it originally. Primary jets and rods are supposed to be #73 and #43B. Would like to confirm that that is correct also, as that is not what was in it.
Thanks, Ron.
Old 11-06-2023, 05:42 PM
Kenth's Avatar
Kenth Kenth is online now
Carter 4887S is actually an aftermarket replacement for all 1969 Pontiac 350, 400, 428 Qjets, exc. Ram Air, as it has the primary pull-over enrichment system and an adjustable idle airbleed under the triangular whasher.
Here is the factory recipe:
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
The Following 2 Users Say Thank You to Kenth For This Useful Post:
Old 11-06-2023, 06:09 PM
54nomore's Avatar
Thank you, Kenth!
This carb was on a '68 YE engine that I acquired several years ago, so I always assumed it was the original carb. Looks like the only deviation was the "J" hanger, as it turns out. 74 and 46(single taper) and BE's were all present.
