Old 11-17-2023, 12:01 PM
Johnny406's Avatar
Johnny406 Johnny406 is offline
Default Old Venolia blower pistons .047 in the hole
Years ago I started to build a new 428 to replace the 455 in my 78 T/A. I started to build the motor and discovered the pistons were well down in the hole, a whopping .047.
I bought the used Venolia blower pistons (.990 pins) from the late Greg Merrick. He had passed before I used them so I couldn't ask him about it.
With that said, I shelved the project for a few years. I did find a set of BBC 6.660 rods and I do have a factory 428 crank with 2.20 rod journals. The pistons will still be .012 in the hole but it's usable.
Idea #1 build it with the 6.660 rod and spray it.
Idea #2 build it with the 6.625 (Eagle ESP .990 pin) rods and put a 6/71 blower on it.
Either way, I would be using my KRE aluminum heads on it with pump E85.
Attached is a old picture showing how far the pistons were in the hole. I believe this was the old style way of running blower pistons?
Thoughts?
Name:	428 deck1.jpg
Johnny US Army Retired
1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph
1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car.
1980 Formula 350 Pontiac back burner project
1972 LeMans 350 Pontiac
Old 11-17-2023, 03:41 PM
Stan Weiss's Avatar
Idea #3 A 6.700" rod and a thicker head gasket
Stan
Pontiac Pump Gas List
The Following User Says Thank You to Stan Weiss For This Useful Post:
Old 11-18-2023, 03:12 PM
Johnny406's Avatar
Stan
The pistons would be out .028 so run a .060 headgasket?
Old 11-18-2023, 03:22 PM
Mr Twister's Avatar
Mr Twister Mr Twister is offline
Butler stocks .055 Cometic head gaskets. I have a set from them for a boost project.
The Following User Says Thank You to Mr Twister For This Useful Post:
