Old 12-05-2023, 07:48 AM
Mr Twister's Avatar
Mr Twister Mr Twister is offline
Default Cam profiles for boost
It would be good to discuss cam profiles for boost on a street engine. Lets say low boost (less than 8) with a roller or hyd roller cam. With the availability of low cost belt driven blowers its time to get the info posted.
Old 12-05-2023, 09:37 AM
Stan Weiss's Avatar
JMO In very general terms for 8 psi (super charger) cam verses an N/A cam. A couple more degrees LSA, a couple of degrees less cam advance, and about 6 degrees more exhaust duration.
Stan
Pontiac Pump Gas List
Old 12-05-2023, 02:47 PM
Johnny406's Avatar
Johnny406 Johnny406 is offline
Here's two custom centrifugal supercharger cams that I had ground for my old 406 back in 2011. Two different approaches for the same motor. These both are HFT, I didn't proceed and stuck with nitrous...
Name:	Comp supercharger cam.jpg
ID:	624457   Click image for larger version
Johnny US Army Retired
1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph
1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car.
1980 Formula 350 Pontiac back burner project
1972 LeMans 350 Pontiac
Old 12-07-2023, 08:25 AM
Mr Twister's Avatar
I get the first one but the second doesn't look like I would expect a blower profile to look like.
Old 12-07-2023, 12:30 PM
Lee's Avatar
Lee Lee is offline
As for profiles, I have started using the HLO and HUC lobe families (CompCam) for boosted motors. A recent customer had valvetrain damage with his previous cam - he was sold a cam with LSK lobes, and this was a motor putting 1,000+ to the wheels!
Overall design, boosted motors don't need much intake duration, and very little overlap. I open the exhaust valve sooner with supercharged motors, and even a bit earlier with turbo motors.
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
Old 12-10-2023, 05:43 PM
blueghoast's Avatar
X2 Less overlap is good for boosted motors, Thats how I run.
GT
Old 12-13-2023, 10:02 PM
70 bird's Avatar
70 bird 70 bird is offline
Pick whatever cam you would like NA and add boost, it will just make more power. For an all-out race motor go custom.
