Old 12-21-2023, 12:31 PM
Red Box Rebel Red Box Rebel is offline
Default ‘68 Serpentine Systems
Has anyone purchased and installed the Serpentine Belt system for the ‘68 and older Pontiac V8s that allow the use of the ‘68 and earlier timing covers?
Not sure of the name of the manufacturer and/or seller. It uses a true serpentine system with spring loaded tensioner(s) instead of threaded adjusters.
Cost is between $2600 and$3000.
Kit comes with A/C compressor, alternator and water pump.
Need to know if this system is still on market and if it is worth the money.
Thank you and Merry Christmas from Ukraine!
The Following User Says Thank You to Red Box Rebel For This Useful Post:
Old 12-22-2023, 09:40 AM
Name of Seller is Eddie’s Motor Sports out of California.
You can get a true serpentine system for $2,650.00 for the ‘68 and older V8s without having to change the front cover to ‘69 and later.
